Cost of 2pac...
#1 _Flamenco_
Posted 13 December 2005 - 04:03 PM
I've never sprayed 2pac before but I know a few people that can do it for me. What's the cost of a few litres of 2pac in relation to Acrylic? It's not going to be a show-winning paintjob, more of a tidyup to make it look more respectable.
Posted 13 December 2005 - 04:50 PM
#3 _Pete_
Posted 13 December 2005 - 05:05 PM
There's been a lot of development of more affordable 2pack paints in the last few years and quite often a cheaper brand of 2 pack will work out better than an average acrylic amount.
Walk into your local automotive paint supplier and see what they sell and get some prices, normally you need 2/3s to half as much 2 pack as you would lacquer, less thinners and you have to buy hardener for your 2pack.
the little extra in cost of 2 pack gives a much better result in the right hands.
i'd guess you may spend maybe $100 more in materials using 2 pack than Acrylic.
Posted 13 December 2005 - 07:12 PM
#5 _Flamenco_
Posted 13 December 2005 - 07:27 PM
Posted 14 December 2005 - 08:54 AM
#7 _postal_dood_
Posted 17 December 2005 - 10:01 PM
im 17 so money is not exactly EASY to come by,.,, lol. i have a mate/family friend that can do the job but im unsure what sort of paint to go for, for the best result, and best price,.
thnx
michael.
#8 _JBird_
Posted 18 December 2005 - 11:29 AM
Flamenco, get your torrie painted 2pak professionally. Save money doing rust repairs yourself. Also go for colours that are non-custom and easy to apply. Generally light colours. White cheapest, Black expensive, Pearl>Custom super expensive.
253toranaSS, you can't do acrylic colour then 2pak clear (regardless of iso free) the 2pak clear wont "bite" or cure properly to the acrylic. I've never seen this combination but I'm sure it won't look good. Just stick with acrylic clear coats and pack it on. Cut and polish like normal and it will look just as glossy.
#9 _JBird_
Posted 18 December 2005 - 11:44 AM
Acrylic would be the go, it is cheap, "easy" to apply, mistakes are fixable, doesn't kill people (still has fumes and you will breathe white snot out unless you wear a mask). Acrylic can be cut and polished to a show quality finish. Any paint job is only as good as the preparation, so spend hours getting the body dead straight in primer phase. Use masking tape on everything.
Acrylic costs per litre around 50 bucks, 4Litres clear, 4Litres colour and a couple of litres of thinners (i think 8, not sure). So if labour is free, it'll cost you around $600 (conservative figure) and a lot of time.
#10 _JBird_
Posted 18 December 2005 - 11:52 AM
Acrylic is softer than 2pak and therefore less durable in country conditions. Stone chips etc. will ruin your job in 2 weeks of daily driving. No paint job will be able to withstand that punishment regardless if it is 2pak or acrylic, but 2pak is harder and will withstand it better.
Regards,
James
Edited by JBird, 18 December 2005 - 11:54 AM.
#11 _postal_dood_
Posted 18 December 2005 - 05:22 PM
thanx JBird 4 all the advice.,
Posted 19 December 2005 - 07:06 AM
Thanks for that mate!253toranaSS, you can't do acrylic colour then 2pak clear (regardless of iso free) the 2pak clear wont "bite" or cure properly to the acrylic. I've never seen this combination but I'm sure it won't look good. Just stick with acrylic clear coats and pack it on. Cut and polish like normal and it will look just as glossy.
