5 speed help
#1 _keaton_
Posted 29 August 2006 - 09:00 PM
#2 _UCV80_
Posted 29 August 2006 - 09:06 PM
there has been loads of topics lately, check em out
,nathan
#3 _uglybob_
Posted 29 August 2006 - 09:42 PM
Posted 29 August 2006 - 11:46 PM
#5 _uglybob_
Posted 30 August 2006 - 12:23 AM
Posted 30 August 2006 - 02:32 AM
#7 _oikurtman_
Posted 30 August 2006 - 10:00 AM
tailshaft mods?
dellow bellhousing?
engineers certificate?
crossmember?
cheers.
Edited by oikurtman, 30 August 2006 - 10:00 AM.
Posted 31 August 2006 - 12:23 AM
1.00 � 0.85 ≈ 1.176ok then yeh i doubt you would want anything higher than that! .85 isnt all that much though. 0.85 is %15 less than 1 : 1 ratio rpm right? thats how you work out how much over drive your getting?
So it's actually closer to an 18% difference.
A 0.78 ratio would be about 28% difference.
#9 _73LJWhiteSL_
Posted 02 September 2006 - 04:30 PM
Depends on which model you are looking at. My understanding is Supra boxes will fit in a LH/X/UC tunnel but not a LC/J tunnel. Celica box should fit in both no problems.so those boxes fit in the tunnel?
tailshaft mods?
dellow bellhousing?
crossmember?
cheers.
From what i understand the tailshaft does need to be shortened, but you need the Toyota yoke to go on the front.
Either Dellow or CRS bellhousing yes
Dunno about engineers.
Yes you need a different crossmember. Dellow or CRS should be able to help you with that as well.
I also understand you need to change the spigot bush and at this stage i understand you run a Toyota preassure plate and clutch plate and a Holden flywheel. Another option is a Toyota 'Dyna' truck clutch i believe.
Steve
Posted 02 September 2006 - 07:07 PM
dyna clutch plate is 10 inch and i dont think will fit a 6cly. also dyna only suits steel case as supra has more splines on input shaft i think.
Edited by ALX76, 02 September 2006 - 07:09 PM.
#11 _oikurtman_
Posted 07 September 2006 - 09:04 PM
Posted 08 September 2006 - 01:34 PM
#13 _The String_
Posted 08 September 2006 - 03:56 PM
Some other posts talk about needing to modify the tunnel, or to weld a small box section on top of the gearbox to stop it hitting the tunnel.
The bloke who is selling the box reckons I need to cut a small section out of the back of the standard gearbox hole, no box section required. I'm not sure how that would work with a standard console. I don't really want to cut the console or go without it.
Any T5'ers advice appreciated
Posted 08 September 2006 - 11:48 PM
#15 _The String_
Posted 10 September 2006 - 08:51 AM
Can anyone advise on whether this is true or not?
#16 _oikurtman_
Posted 10 September 2006 - 01:09 PM
#17 _redlh_
Posted 10 September 2006 - 01:22 PM
I've had the box in place for 4yrs without any problems at all (although the reverse synchro is starting to play up a little). With the 3.0 gears in the 9", the T5's overdrive makes the unlimited speed limits up here in the Territory a lot easier on the engine and on petrol.
#18 _micksgtr_
Posted 24 September 2006 - 10:24 PM
i was also told that th vr ss bellhousing will fit and the clutch from a UC will bolt straight up?? can anyone confirm?? alo wat clutch set up are you using??
Posted 25 September 2006 - 01:07 AM
I have a T56 fitted and didn't cut a thing and also retained the same shifter location as a M21.
#20 _JBird_
Posted 25 September 2006 - 04:30 PM
#21
Posted 26 September 2006 - 01:49 AM
I used a Mal Wood kit which required the input shaft of the box to be modified slightly. Bit stronger than a supra or T5 if your thinking of going a little harder in the hp and torque dept.
Dave
#22
Posted 27 September 2006 - 01:00 AM
Both T5's I have are mech. speedo.
Edited by rodomo, 27 September 2006 - 01:04 AM.
#23 _Red Dragon_
Posted 27 September 2006 - 06:01 AM
#24 _Keithy's_UC_
Posted 27 September 2006 - 07:26 AM
Keith
