No power
#1 _BoltZ_
Posted 30 August 2006 - 01:02 AM
Tried to start the torri up tonight.... and like the thread topic says, no power was present. Figured the battery was dead, so i charged it, reconnected it and still the same result. No spark when terminals connected (which are quite new), no interior light.... absolutely nothing.
I last started the car on Sunday, with no problems. Haven't touched it since.
Any ideas on what this could be? Where could i start? And what could've caused it?
Thanks guys
Posted 30 August 2006 - 01:04 AM
Posted 30 August 2006 - 01:08 AM
#4 _devilsadvocate_
Posted 30 August 2006 - 08:29 PM
#5 _BoltZ_
Posted 30 August 2006 - 08:56 PM
#6 _Yella SLuR_
Posted 30 August 2006 - 10:25 PM
#7 _devilsadvocate_
Posted 31 August 2006 - 07:18 AM
#8 _Yella SLuR_
Posted 31 August 2006 - 09:17 AM
I have a torrie in bits atm, so can go on a search, but never seen one so not sure what I'm looking for. Need somebody with Autoelectrician experience (Dangerous???).
Edited by Yella SLuR, 31 August 2006 - 09:18 AM.
Posted 31 August 2006 - 09:29 AM
sometimes if the main feed is yellow the link is white or red and if the feed is red the link is white. most always a different color.
Edited by ALX76, 31 August 2006 - 09:30 AM.
#10 _devilsadvocate_
Posted 31 August 2006 - 09:33 AM
Edited by devilsadvocate, 31 August 2006 - 09:34 AM.
#11 _devilsadvocate_
Posted 31 August 2006 - 09:54 AM
Boltz, with your test lamp or multimeter, start at the battery and find the point at which you lose voltage.
1. Measure volts across batt, OK?, then proceed
2. Measure volts between starter terminal/batt lead and earth
3. Trace red wire that goes from starter to harness connector, push probe in terminal here, again measure voltage between that and earth. Do this on both sides of the connector. If your prob is here, fusible link gone or if only on one side of the connector......bad connection.
4. If so far so good, keep going onto the inside, next stop is the ignition switch.....good luck.
#12 _BoltZ_
Posted 31 August 2006 - 10:01 AM
Posted 31 August 2006 - 12:14 PM
I'm with Devil's on this one, I've never seen any Holden with a fusible link mounted on top of the steering column. AFAIK they're part of the wiring harness where the 12v supply comes off the starter motor terminal.
The checklist that he has listed is a good logical one, except I always prefer to use a test-light. Multi-meters, especially digital ones, can lead you astray.
Dr Terry.
#14 _Yella SLuR_
Posted 31 August 2006 - 04:46 PM
Actually, as a separate post, does somebody want to throw up how to test the battery? I always rely on the dudes at the Battery Factory to test it all. Looks pretty simple, but never catch exactly what they do as they have me in the car doing the high beam thing. May be useful for all us out here in forum land. If the battery ain't holding charge, all the battery charging in the world aint going to help.
Edited by Yella SLuR, 31 August 2006 - 04:50 PM.
#15 _devilsadvocate_
Posted 31 August 2006 - 05:23 PM
1. Make sure the battery is as charged as it can be, by putting it on a charger for a few hours or ensuring that it has been getting 14V from the alternator.
2. Put voltmeter across terminals
3. Disconnect spark lead from coil
4. Crank starter for 10 sec......observe
If the battery goes below 10V, it is going to prove problematic in starting the car......sooner or later.
If it stays above 10.5V......its in good shape for your demands.
#16 _BoltZ_
Posted 01 September 2006 - 08:25 PM
Don't know WTF happened, but seems to be working again now
I'll keep all this for future reference in case the ghost strikes again. Damn electrics!
#17 _devilsadvocate_
Posted 01 September 2006 - 09:44 PM
Posted 01 September 2006 - 11:19 PM
No seriously.. make sure that the bonnet isnt touching anything anywhere that could cause a short! Something may be stuck somewehre in the moving hinge area!
Posted 02 September 2006 - 08:43 AM
Good Luck!
#20 _devilsadvocate_
Posted 02 September 2006 - 03:22 PM
#21 _switchedon_
Posted 10 September 2006 - 05:59 PM
cheers james.
