Rochester APT screw setting
6 replies to this topic
#1 ScottB
ScottB
  • 13 posts
  • Name:Scott
  • Car:UC Hatch
Posted 21 April 2021 - 03:33 PM
Hi,
I'm playing with a VK (?) Rochester (17084595 1464 JHT). I have a rebuild kit to put in and I've disassembled the carb today.
This model has an internal adjustable APT screw to set part throttle mixture I believe.
Being a newbie knucklehead, I didn't note the number of turns out from seated before removal. Plus I think someone has already been into the carb so who knows how it was set!
Is there any way to get the factory setting from somewhere? Or a close starting point?
Scott
#2 arrimar
arrimar
  • 3,123 posts
Posted 21 April 2021 - 03:53 PM
Go to Ross at Carbotune Tweed Heads.
He'll set it up properly.
#3 ScottB
ScottB
  • 13 posts
  • Name:Scott
  • Car:UC Hatch
Posted 21 April 2021 - 05:42 PM
Thanks arrimar. I'll keep him in mind.
#4 rodomo
  • 17,999 posts
Posted 22 April 2021 - 09:49 PM
Try in till it seats then back out 3/4 turn. Worked on ol' strommies as a starter position?
*Disclaimer............might have been 1 and 3/4 turns.................been a while
#5 Dr Terry
Dr Terry
  • 3,276 posts
Posted 23 April 2021 - 04:50 PM
Different screw, I don't think that Scott if referring to the idle mixture screws.
AFAIK the APT screw in Qjets sets the lower height of the primary piston.
Dr Terry
#6 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 23 April 2021 - 11:52 PM
That is correct Dr Terry.
This may help, I've got this in books, but this gives a good description.
Edited by warrenm, 24 April 2021 - 12:00 AM.
#7 ScottB
ScottB
  • 13 posts
  • Name:Scott
  • Car:UC Hatch
Posted 24 April 2021 - 10:35 AM
Thanks for the info.
Yeah I've been searching the net for videos and opinions on the setting point. Thanks for posting that video warrenm, it's a good explanation. So far I've read set points anywhere from 2 to 4 full turns out from seated. So I reckon I'll pick 3 turns as a start point.
I have ordered the grub screw kit from the US. So at least I'll be able to tune it once the engine starts.
Scott
