stroker kits
#1 _torana06_
Posted 30 August 2006 - 08:54 PM
just was looking into stroker kits for 308 to 336
apart from the actual kit what parts also need to be strengthened/changed
e.g engine and driveline and their prices.
what stock components can i keep.
how much on average does this setup cost in total to install from others previous experiances
any advice appreciated
Posted 30 August 2006 - 09:08 PM
depending on which setup you go and which block you have, the block may need machine work (and in extreeme cases the sump) too.
#3 _torana06_
Posted 30 August 2006 - 09:20 PM
how much all up would you say it costs
Posted 30 August 2006 - 10:16 PM
best you ring a few places for costs as this can vary from under $1000 DIY to several thousand ready to bolt in or ready to go.
there are that many types and ways to stroke a motor i cannot begin to explain them but each have their merrits for their given application.
#5 _LH SL/R 5000_
Posted 30 August 2006 - 10:51 PM
A stroker will increase your power but the main thing is TORQUE. Torque is what will kill your tranny.so transmission can handle the power
#6 _MAWLER_
Posted 30 August 2006 - 11:27 PM
Posted 31 August 2006 - 11:32 AM
they are actually in Heathcote now, I can recommend them, they are great to deal withRing Pro-Stroke and talk to them, Melbourne mob so you could even go down and check em out if you wanted. I've got a small stroker pro stroke kit in my 308.
#8 _torana06_
Posted 31 August 2006 - 11:50 AM
and what extra power and torque did you get
#9 _MAWLER_
Posted 31 August 2006 - 02:10 PM
#10 _torana06_
Posted 31 August 2006 - 04:02 PM
#11 _MAWLER_
Posted 31 August 2006 - 04:32 PM
They are also mid-way between the 308 and 355 where they create more torque than the 308 but still spin up a bit higher than might be expected with the 355.
My engine is running a large solid cam, standard VN heads, harrop dual plane manifold and Holley 750Dp and is making 400HP
Cheers,
#12 _micksgtr_
Posted 02 September 2006 - 02:06 PM
#13 _torana06_
Posted 03 September 2006 - 01:51 PM
