I just got her back from the Auto Electrician,I had to get some other wiring red-done so I got them to wire these up too but I wish I had tried to do it myself now as the bill$$$$ was huge!(IDIOT!). a few weeks back my work car(toyota T18) wouldnt start,so I was swapping batteries around at 5:00am! using a torch and to cut a long story short I put the battery terminals on the Toranas battery round the wrong way!
Whats the prefered mark that the fans should come on at???,the sparky said I should have put the fan controller in the Manifold instead of the radiators top tank,which is what I was originally going to do but the Radiator guy said to put it in the radiator. I am told if put the controller in the manifold then it WILL kick on at 85 as the coolant there is hotter(makes sense),I need to test these out more though(only dove out 8-10 kms with them so far). While I am here I am using that TECTALOY 60 Plus coolant is this good enough??,what do you lot use?
Sorry for all the questions folks...................
