Red manifold Blue manifold, interchangeable?
17 replies to this topic
#1 _wb_82_
_wb_82_
Posted 12 September 2021 - 08:30 PM
Hey fellas,
When I rebuilt my Blue 308 pollution engine a decade ago, I installed an edelbrock performer manifold due to corrosion issues on the original manifold - problem is it's not going to allow me to comply with ADR27 rules because of the lack of EGR support for the upcoming blue slip.
The car is a 1980 WB caprice 308.
I have two spare manifolds, the original is completely unusable as the water jackets have completely corroded please see blue pic attached.
The second spare manifold looks to be off a red engine, as I can see orange paint on the front vacuum switch and I have noticed that rear vacuum tree is a little offset, and has less vacuum branches compared to original please see Red pic attached.
Does anyone know if I can run the red pic manifold on a blue 308 motor?
Appreciate any input!
#2 LCK186
LCK186
  • 335 posts
  • Car:71 CK
Posted 13 September 2021 - 08:18 AM
hi the photo on left side is for 1977 holden    same as the A9X    I cant see why u cant use it meets up with all standards
#3 _sbc57lx_
_sbc57lx_
Posted 13 September 2021 - 08:57 AM
Check the bolt locations near the EGR -  and the shape of the EGR,s     I don't think you can use a red manifold on a blue motor.
#4 308 Sunbird
308 Sunbird
  • 966 posts
  • Name:Stuart
Posted 13 September 2021 - 10:05 AM
Sorry but no good for your blue heads. Check centre bolts to heads- two extras on blues and
slightly different locations mean they don't line up from what I remember.
#5 rexy
rexy
  • 3,602 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 13 September 2021 - 10:44 AM
Just run the gauntlet?
It will likely get passed as is.
#6 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 13 September 2021 - 01:12 PM
It'll fit. I wouldn't bother with the centre bolts, just don't overtighten the others
#7 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 13 September 2021 - 05:55 PM
dont think it will fit .The manifold will not cover the egr port on the heads .
flip it over and you should easily see why
Edited by UCSLE, 13 September 2021 - 05:56 PM.
#8 _wb_82_
_wb_82_
Posted 13 September 2021 - 07:10 PM
Ahh yeah you're right mate, I didn't even notice that at all.
Thanks for the input all.
#9 _wb_82_
_wb_82_
Posted 13 September 2021 - 07:14 PM
Hi mate,
The guy doing the blue slip, said the car should be how it rolled off the showroom floor or I need to pay somewhere in the vicinity of $2000 to have the new manifold setup tested by an engineer to make sure it complies with emissions standards! Crazy.
I think I would rather pick up a standard manifold.
Edited by wb_82, 13 September 2021 - 07:15 PM.
#10 S pack
  • 15,541 posts
Posted 13 September 2021 - 08:21 PM
Agree, the EGR passage was relocated in the blue head castings and the two centre bolts straddle the passage.
Can the corrosion to the original manifold be welded up and machined to restore it?
Edited by S pack, 13 September 2021 - 08:22 PM.
#11 rexy
rexy
  • 3,602 posts
  • Name:Rexy
Posted 13 September 2021 - 09:40 PM
Hi mate,
Honestly I would be asking around for a more reasonable blue slip examiner.
Not many left with original everything.
In Gladysville somewhere I presume?
#12 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 14 September 2021 - 12:51 AM
Hi mate,
I'd fit a EGR delete and then the red mani, pass engineering then fix properly
#13 _Lazarus_
_Lazarus_
Posted 14 September 2021 - 10:00 AM
https://www.ebay.com...eb&toolid=10049
#14 Ice
  • 15,126 posts
Posted 14 September 2021 - 11:49 AM
Just weld and machine  the one you got cheapest option
#15 _Lazarus_
_Lazarus_
Posted 15 September 2021 - 07:19 AM
He may not notice my link because of your pointless comment.
Go and stalk someone else, you're starting to look obsessed.
#16 S pack
  • 15,541 posts
Posted 15 September 2021 - 07:46 AM
The manifold in the link you posted needs some corrosion repairs to the thermostat housing boss.
Attached File  308 blue manifold.jpg   220.93K   4 downloads
The OP would be best to investigate getting his manifold repaired before buying another one in similar condition.
Edited by S pack, 15 September 2021 - 07:47 AM.
#17 Ice
  • 15,126 posts
Posted 15 September 2021 - 08:35 AM
Obsessed wow that strong coming from you
Talk about pointless links
Your the frOckin gold medalist at it you twat
You’re obsessed to now   :)
#18 VZ1_60
VZ1_60
  • 52 posts
Posted 15 September 2021 - 06:55 PM
black (VK) intake manifold for sale in WA on Marketplace, 3 bolts on the exhaust crossover, $190, has EGR, no thermo housing on it, looks to be a bit of corrosion on the water jacket area, this is not mine and I do not know the seller, cheers
marketplace item 362883552158570
