Any recommendations for sealants to use when fitting tail lights to the car body.
Sealant for LJ Tail Lights
Posted 16 January 2022 - 06:33 AM
Posted 16 January 2022 - 07:17 AM
Posted 16 January 2022 - 09:03 AM
^^^^ I used Bostick black windscreen sealant which is similar to mastic.
Posted 16 January 2022 - 09:38 AM
Posted 16 January 2022 - 10:48 AM
Thanks guys. Has anyone got any pictures of how much to use. Also I saw this stuff "3M Window-Weld Ribbon Sealer" Any thoughts on this product. Sealing Rear Tail Lights to the Car - YouTube
Posted 16 January 2022 - 11:21 AM
Just get a tube ,apply it around the lens housing ,you can cleanup excess with mineral turps.
Posted 16 January 2022 - 11:55 AM
Okey Dokey, Thanks everyone for your help. While yous are here, Best floor underlay recommendations to please.
Posted 16 January 2022 - 12:07 PM
A lot of people use dynamat,it’s a stick on underlay ,I used the underlay from Knox carpets.I can’t tell you which is better ,but I didn’t want anything stuck down on the floor.
Posted 16 January 2022 - 01:36 PM
Yep same ^^^
Posted 16 January 2022 - 02:36 PM
Used this 3M sealant. It is good stuff. Bit hard to get hold of but worth the effort
Posted 16 January 2022 - 03:00 PM
Look at the mating surface as has been said & yes wax & grease ect clean up, just like a windscreen. Use a quality W & g & if you have already polished the car, the w & g will remove the polish. Do the job in the shade.
Posted 17 January 2022 - 12:15 PM
Do you need to take chrome surrounds off ?.
Posted 17 January 2022 - 01:09 PM
Posted 17 January 2022 - 03:47 PM
