Caliper pin length
22 replies to this topic
#1 goxu1
goxu1
  • 690 posts
  • Name:Paul
  • Car:4/73 Cyan Metallic GTR XU-1
Posted 08 February 2022 - 09:41 PM
Anyone know what the length of the caliper pin should be for the xu1?
I bought a set off eBay and they seem to short.
The hole for the clip is hard up against the caliper making the clip impossible to engage
#2 S pack
  • 15,541 posts
Posted 08 February 2022 - 11:39 PM
The LJ parts catalogues list the same brake pad retaining pin and clip for all 6cyl calipers.
#3 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 09 February 2022 - 07:33 AM
Would have to be quite a bit longer than standard with the spacer and thicker disc?
#4 Dr Terry
Dr Terry
  • 3,276 posts
Posted 09 February 2022 - 08:46 AM
It might be from an HD/HR or Cortina, which are similar but slightly shorter.
AFAIK all LC/J (6-cyl) & all HK/T/G calipers use the same length pin, p/no. VS10759.
Dr Terry
#5 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,293 posts
  • Car:ɐuɐɹoʇ
Posted 09 February 2022 - 12:56 PM
goxu1
The pins go from the inside to the outside on the Girlock calipers.
Bazza
#6 goxu1
goxu1
  • 690 posts
  • Name:Paul
Posted 09 February 2022 - 01:35 PM
just going off this pic from stevemc32's build I can see there is plenty of pin hanging out to get the clip on.
But the ones I bought off ebay only hang out about 5mm and theres not enough room to get the clip on due to the shape of the casting.
So I was curious to know the length of the pin from the underside of the head to the end....
#7 Dr Terry
Dr Terry
  • 3,276 posts
Posted 09 February 2022 - 03:47 PM
Those pins aren't the same as the originals.
Look at the pic & the R-clips go thru the pin much closer to its head, so the caliper casting shape will have no effect.
Try to find some closer to the originals.
Dr Terry
#8 S pack
  • 15,541 posts
Posted 09 February 2022 - 06:45 PM
The original brake pad retaining pins are 65.5mm long from the underside of the mushroom head.
Attached File  20220209_182847_resized.jpg   119.79K   3 downloads
Attached File  20220209_182746_resized.jpg   368.11K   2 downloads
Attached File  20220209_182707_resized.jpg   124.16K   3 downloads
#9 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 09 February 2022 - 08:37 PM
#10 S pack
  • 15,541 posts
Posted 09 February 2022 - 09:05 PM
Almost the same. The LC/LJ pins are a few mm longer.
#11 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 09 February 2022 - 10:51 PM
My short term memory failed me Dave. I thought you had said 64mm. So HR are 1/8” shorter. Did all the LC LJ sixes have the 5/8” discs then? I thought it was only GTR, XU-1 and KTG v8.
#12 S pack
  • 15,541 posts
Posted 10 February 2022 - 06:31 AM
Hi Clay, only the XU1 had the thicker 15.6mm rotors. The GTR and the J52 optioned S & SL had the 12.7mm rotors.
I believe the HR rotors were 9.7mm thick.
#13 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 10 February 2022 - 08:15 AM
Thanks Dave. I had the original rotors on my HR brakes for years. They were a composite and 10mm sounds right from memory. The outer layers were nearly worn through when I replaced them with a one piece disc which seemed thicker, but of course it would being new.
#14 S pack
  • 15,541 posts
Posted 10 February 2022 - 08:27 AM
Genuine HR rotors were not a composite construction, they were a one piece casting, however they were separate to the wheel hub.
#15 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 10 February 2022 - 09:11 AM
Yes separate to hub, but I am fairly sure these were original, and were certainly well worn in 1986 when I got them. They had a steel laminate on the braking surface, over cast main body.
#16 Dr Terry
Dr Terry
  • 3,276 posts
Posted 10 February 2022 - 09:37 AM
I don't think that was the case. My memory of all original HD/HR, LC/LJ & HK/T/G rotors were that they were cast iron, with a steel ring at the outer edge to reduced harmonic noise. They look to be laminated, but are not.
All of the aftermarket replacements were just cast iron, with square edge & no steel ring.
Dr Terry
#17 Dr Terry
Dr Terry
  • 3,276 posts
Posted 10 February 2022 - 09:42 AM
Yes, the XU1s had a 5/8" thick rotor, all other disc braked LC/LJ (6-cyl) had 1/2" thick rotors.
The HK/HT/HG disc rotor thing is more complicated. All HK had 1/2" rotors, all HT also had 1/2" rotors except for the Monaro GTS350. Then all HG (6 or V8) got 5/8" rotors.
HD/HR got 3/8" rotors & shorter pins.
Dr Terry
#18 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 10 February 2022 - 09:49 AM
Thank you good doctor. Can you comment on the HD HR rotor composition? I distinctly recall the cast rotors having a steel surface laminated on the friction area.
It did appear that way. It looked to have 2 thin layers either side of a steel spacer, but it wasn't quite like that.
As I said, it was basically a cast iron disc with a steel ring at its outer edge.
Dr Terry
#19 S pack
  • 15,541 posts
Posted 10 February 2022 - 12:21 PM
Dr T is correct. The OEM rotor was solid cast iron with a groove machined in the periphery of the rotor and a steel ring installed in the groove.
Edited by S pack, 10 February 2022 - 12:21 PM.
#20 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 10 February 2022 - 12:27 PM
Missed your first comment Dr T. Yes it appeared to be a laminate but it wasn’t. I remember being concerned that the “laminate” was going to either wear through or delaminate and seize. Thanks for the clarification guys.
#21 Dr Terry
Dr Terry
  • 3,276 posts
Posted 10 February 2022 - 01:33 PM
What used to happen in extreme wear situations, was that the cast iron wore so thin that the outer ring came loose & got mangled between the wheel & the caliper.
Dr Terry
#22 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 10 February 2022 - 06:42 PM
Yes I would say that is what was imminent with mine in hindsight thanks Terry and Dave.
#23 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 09 September 2022 - 03:57 PM
I got hold of a set of HR discs, calipers, hubs and stubs recently. Thanks to Bruiser for backing plates as well. The calipers are minus pins so will have to source some, along with pistons and rotors.
Here is a picture of the original rotor showing the harmonic balancer ring. These are close enough to end of life. Looks like the ring was tack welded here. I guess they would have been like a big snap ring.afb7da9d87d8c934d967a23637237f52.jpg
