Banjo Diff Centre Housings
2 replies to this topic
#1 natcamp10
natcamp10
  • 113 posts
  • Name:Nathan
  • Car:Lj torana
Posted 11 February 2022 - 09:48 AM
Hey all
Im building a Lh diff centre and ive got 2 options for diff centre housing whereas one housing from looks has extra support around the outside at the bottom possibly for the pinion bearing
Can some explain why and which housing would berecommended .
It will be built with the harrop true trac Lsd with billet axles
Behind a mild 308
Nath
#2 S pack
  • 15,541 posts
Posted 11 February 2022 - 10:04 AM
Sounds like you have a 3.08/2.78 ratio carrier and a 3.55/3.36 ratio carrier.
The 3.08/2.78 ratio carrier has the "extra support" around the outside at the bottom. It requires two long mounting bolts rather than 1 short bolt (drain bolt) and a stud.
Select the carrier that suits the ratio you intend to use.
Edited by S pack, 11 February 2022 - 10:06 AM.
#3 hanra
  • 10,832 posts
Posted 11 February 2022 - 11:38 AM
I know this has been discussed before and what ratio will fit what carrier etc.
Ive actually got a 3.55 LSD centre mounted to my 2.78 carrier. I didnt realise the differences at the time and the workshop that rebuilt the centre, mounted it to the 2.78 carrier which at the time has a 3.08 centre attached.
