Correct rear bumper middle bracket to body bolts.
Posted 07 May 2022 - 09:08 PM
Are they the same as the 5/16" unc bolts on the bonnet catch and other front end parts?
Posted 07 May 2022 - 09:32 PM
Posted 08 May 2022 - 04:00 PM
Posted 08 May 2022 - 04:38 PM
Posted 08 May 2022 - 06:33 PM
Posted 08 May 2022 - 10:11 PM
I just looked in the parts catalogue and the 4 outside bracket bolts have a specific part number but the inner ones don't. There appears to be a flat washer on the inside of the boot and a spring washer under the nut on the outside of the bracket.
James, the bolts are the same for all the brackets. The parts cat drawing only identifies one bolt to one outside bracket. There is no need to identify each individual bracket mtg bolt as they are all the same.
The pic is also a little deceptive as it must be early LC. If you look at your two LJ rear facing brackets you will find the nut is factory electrofusion welded to the bracket. No spring or flat washers can be inserted between the nut and the bracket.
Edited by S pack, 08 May 2022 - 10:14 PM.
