UC Tach Cylinder Adjustment
5 replies to this topic
#1 hanra
  • 10,832 posts
Posted 21 October 2022 - 08:15 AM
Is it possible to change a UC tach from 4 cyl to 6 cyl? Is there a switch like the LH Tach has?
#2 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 21 October 2022 - 04:58 PM
Doesn't look like there is a switch , there is something in the second pic i took but dont know what it is
Attached File  tach1.JPG   64.88K   4 downloads
Attached File  tach2.jpg   206.49K   6 downloads
#3 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 21 October 2022 - 05:45 PM
That is a potentiometer.
#4 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 21 October 2022 - 06:15 PM
figured that much but whats its range , whats it do and can you use it to tune to a 6cyl ?
Edited by UCSLE, 21 October 2022 - 06:16 PM.
#5 hawk
hawk
  • 2,143 posts
  • Name:steve
  • Car:UC Torana
Posted 21 October 2022 - 07:52 PM
I've read up a lot on this lately trying to get my dash to work. I believe you can get it to work with the potentiometer, if not there is a way to swap a resistor and make it suit. Google search through the forum and you should find some info on it.
#6 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 12 November 2022 - 08:45 AM
That is indeed the calibration potentiometer.
However, you'll need a square wave signal generator to set it for 6 cyl.
Most instrument shops will re-calibrate it to 6 cyl for around $50.
