Here is two of the HQ's. Will run through the process.
Starting point is the preliminary list of 42 cars required for the Press Fleet. This is a cut of cars 15-17 off that list:
HQ press fleet early snippet cars 15-17.jpg 150.3K
6 downloads
The cars of interest here are eventually cars 15 and 17. They had decided upon what the cars were to be at this stage but no info on where they would be built or the Car to Sales date. These three are NSW Press Fleet Cars. Car 16 you can see was to be a HQ GTS coupe, but GMH cancelled the HQ GTS coupe in December 1970, see below. They replaced the GTS's for VIC, QLD and SA fleets with V8 GTS but reduced the numbers from 42 to 41 by removing the NSW GTS.
HQ GTS cancellation.jpg 274.58K
6 downloads
And here is the same list but after the cancellation of GTS. you can see "out re letter Dec 11" next to the GTS plus penciled numbers against the cars. They have also written in which VAP were to build the cars:
HQ press fleet snippet after GTS cancellation 15-17.jpg 165.79K
7 downloads
Here is the final hand markup. The Car to Sales dates are shown in red pen over to the left, The next red 3-digit number is the order number. Plus some changes to the specs for the cars:
HQ press fleet later snippet cars 15-16.jpg 84.08K
6 downloads
There is numerous correspondence about delays, when cars are to be ready etc that helps nail a few of them. Luckily two of the cars that were impossible to nail (VIC Press Fleet, Dandenong build 80169 and 80369) were finished by the time off memo issue and had PSN's against them in one memo I found.
End result, here are the two cars off the HQ records, they are the only cars that fit the specs (by BETSBAC) at the VAP with 000 S codes plus with dates that work. As you can see the completion dates are about 3 weeks after the stated Car to Sales dates which is about right in this timeframe. Car to Sales is when the car begins to become a product rather than being a schedule entry. You can see the 000 S against them as they are internal cars, and they are S zone office as they belong to the NSW Press Fleet.
HQ press fleet examples.jpg 31.65K
4 downloads
So here is the Belmont I believe. This article tests three NSW Press Fleet cars, and the 202 auto Kingswood sedan is also white but it had a black vinyl roof. This gives me a number plate for a car:
Wheels Sept 1971 page 9.jpg 325.1K
2 downloads
