Just wondering if anyone has replaced plastic cog in Lc/LJ wiper motor. MIne had stripped (plastic spline flogged out) which stopped wipers from working. I managed to source another one but thread on end of metal shaft has broken off. I am worried that punching good cog off broken shaft might break it, as it is old and brittle which is what happened to flogged out cog, when i removed from good shaft. Welding a small piece of threaded rod onto broken shaft might melt good cog. Any advice or help greatly appreciated: Paul
Wiper Motor Cog Drive
Posted 15 January 2023 - 06:19 PM
Posted 15 January 2023 - 06:37 PM
Posted 15 January 2023 - 06:39 PM
Posted 15 January 2023 - 07:47 PM
Thanks dave, do you think cog will break if i try and remove from broken shaft? If i cant come up with any other ideas, i will use your suggestion and let you know how i went. Regards Paul
Posted 15 January 2023 - 08:00 PM
https://www.preslite...ducts-list.html
Also here:
https://abouttimespa...-stock-(genuine)-Probably-early-Holden-/-Falcon-55mm-o/d-8cm-long
Edited by yel327, 15 January 2023 - 08:04 PM.
Posted 15 January 2023 - 08:08 PM
Hey YEL327, they are a Lucas unit, but i might give them a ring in the morning to see if they sell spare parts for their units which might fit mine. Thanks for the heads up, i appreciate it: paul
Posted 15 January 2023 - 08:36 PM
I believe you will be tempting fate if you remove the plastic cog.
Posted 16 January 2023 - 06:32 AM
I totally agree, will stick with plan A
Posted 17 January 2023 - 02:29 PM
Hey Dave, went with plan A (your suggestion) and worked great. Not sure how long will last but rarely drive car in rain anyway, and if replacement cog strips, might weld a small semi circle lug either side of main shaft, then file same shape out of cog to stop rotating on metal shaft.
YEL 327, tried to contact both places in your links without success, they may no longer be in business? Was worth a try anyway,
Paul
Posted 17 January 2023 - 05:47 PM
Paul
Cool Paul, knew the repair would work and if you put locktite on the thread it will last many years to come.
Posted 17 January 2023 - 06:07 PM
Yes locktite and roller pin
Posted 17 January 2023 - 07:39 PM
Someone needs to CAD those gears and 3d print them...
Posted 18 January 2023 - 10:54 PM
Yes, i was thinking the same thing, not sure what other vehicle make and models these motors were fitted too, but there would be a market for them i think!
Edited by lctriples, 18 January 2023 - 10:55 PM.
Posted 19 January 2023 - 10:52 PM
If I had a good one to copy I could make a mould and resin pour them. Tricky bit is making sure they have the strength, don't want teeth snapping off at the first sign of use.
IMG_9195.jpeg 77.41K 3 downloads
IMG_9196.jpeg 182.83K 3 downloads
IMG_9197.jpeg 140.63K 2 downloads
IMG_9239.jpeg 108.78K 3 downloads
Marty
Posted 20 January 2023 - 04:48 AM
Edited by IanC, 20 January 2023 - 04:48 AM.
Posted 20 January 2023 - 01:22 PM
Ian: Very similar to "Rapid Fix" product/concept i reckon.
Marty: I have the broken cog you can use to experiment if you want. It is intact except for centre spline which has worn away. I was thinking more along the lines of 3D CAD printing where you could scan cog into PC and use really hard plastic through the 3D printer. How hard a plastic can you mould with?. Would be great to offer to forum members like you did with heater control lettering you sent to me.
Paul
Posted 20 January 2023 - 07:15 PM
Paul
Hi Paul, If you want to sent me the cog and centre spline I can start experimenting.
Marty
Posted 28 January 2023 - 01:41 PM
I've successfully punched out the steel shaft by sitting it upside down on a vice adjusted up close to the shaft for rigity, and punch it through.
To put the new shaft in, place the gear flat on a bench, a light smear of adhesive on the splines and tap the shaft down gently (it goes in pretty easily). Remember to screw a couple of nuts onto the thread so you're hitting the nuts, not the thread. Tap it through to where you want it.
I've done this several times.
Posted 30 January 2023 - 08:06 PM
Hey Chris, thanks for that. good to know down the track, what type of adhesive did you use? Thanks Paul
Posted 31 January 2023 - 08:36 AM
Just a very small amount of epoxy is adequate.
#21
Posted 01 February 2023 - 05:26 AM
Thanks Chris
