Please Help me if you can…
Wondering if by chance somebody currently has the crossmember dismantled from their LJ, As after tearing the garage apart 2–3 times I’ve finally found the 12 large washers for radius rods, crossmember into k-frame etc. and alignment shims that are taped together in sets and marked with correct location…
But unable to locate the 20 or so bolts to reassemble the crossmember back into car.. I’m needing just 1 of each bolt, associated washers and nuts ( either new or old ) so that I can measure for purpose of sourcing all new items to bolt everything back onto the K-Frame / crossmember…
Happy to buy an old set and then return them after a week or 2 once I’ve used them for measurements ie:: Lengths & diameter.. I really only need 1 of each bolt, washer & nut if required, plus indication of the amount of those bolts thats required to rebuild this part for my “what’s now turning into a longer than long term project”
Any Help Will Be Greatly Appreciated…
Kind Thanks..
Whale/Oil…
