Hi all
I have never come across this phenomenon before and it has me stumped.
Newly reconditioned big nut master.
New pistons and seals in calipers in original Girlocks.
New flexible hoses.
Measured booster pushrod length using 3 diffiernt methods - always results at around 25mm protrusion.
The problem is the system won't bleed properly. Tried 4 different methods. I reinstalled a known good after-market master but it made no difference.
If I pinch off just the rear flex hose - no pedal.
If I pinch off just the front right hand flex hose - no pedal.
If I pinch off the rear and front right flex hoses - no pedal.
If I pinch off just the left front flex hose - good pedal.
This points to a problem with the left front caliper. I have pulled it apart numerous times and the bores are still whistle clean and the pistons move well. Good flow of fluid when bleeding by different methods.
As a last resort I split the caliper looking for trapped grease (I used the grease gun method when I popped the pistons) - whistle clean.
No fluid leaks anywhere.
Any clues folks?
Bazza
