LC seatbelts
2 replies to this topic
#1 Flaming Skull 57
Flaming Skull 57
  • 112 posts
  • Name:John Harris
  • Car:LC Torana "Gilberts Stinger"
Posted 02 June 2023 - 08:49 PM
Hi All.
I would like to know where each seatbelt goes on a LC two door.
Where does the very short female belts go.
I also have two adjustable female belts.
Also I have a two long adjustable male belts and two that are a bit shorter. Which goes to the front and which to the back?
John
#2 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 03 June 2023 - 08:31 AM
For the female belts the rear lower female belts are shorter than the front female lowers.
There will be variations between year models and assembly plants as 3 different belt manufacturer's were used.
I think that the adjustable female belts may be for the front. However these were non adjustable in an Adelaide built 73 LJ.
So if you have adjustable female belts I'd assume that they would be paired with non adjustable male belts and vice versa.
#3 Flaming Skull 57
Flaming Skull 57
  • 112 posts
  • Name:John Harris
Posted 03 June 2023 - 03:08 PM
Thank You
