NZ XU-1
17 replies to this topic
#1 skap
skap
  • 1,057 posts
  • Name:Skap
  • Car:Mighty VN
Posted 18 June 2023 - 12:06 PM
Just saw this on trademe....
https://www.trademe....ting/4150342865
So close to my old car.
Note, another NZ new car with the ADR plate still attached.
Year: 1972 Make: HOLDEN Model: TORANA Colour: Green Submodel: GTR XU1 Body Style: Saloon VIN: 7AT08903X20215021 Plate: GF1890 Engine No: JP220596 Chassis: 82911JL215021 CC rating: 3,310cc (3.3l) Fuel Type: Petrol
#2 RallyRed
  • 7,846 posts
Posted 18 June 2023 - 12:30 PM
Geez, standby for a rod thru the block.
Bathurst + 3.55/1 = dramas I would have thought. Maybe just getting numbrrs up for homologation.
I guess those ammemdment docs would confirm or otherwise.
#3 S pack
  • 15,541 posts
Posted 18 June 2023 - 01:01 PM
Haha, higher compression engine, what a load of BS. The static compression ratio never changed throughout LJ XU1 production.
#4 jpxu1
jpxu1
  • 549 posts
Posted 18 June 2023 - 02:07 PM
Wow! While it looks to be a good solid survivor car there are a mountain of issues to be addressed to get it back to stock original, with changed/missing parts noted in the few available photos.
"Special heavier springs" are news to me - haven't been able to find them listed in any of the parts books :-)
In its current state I would be looking to pay closer to half the asking price.
JPXU1
#5 S pack
  • 15,541 posts
Posted 18 June 2023 - 02:16 PM
JPXU1
Homologation 5/5V for the 72 Bathurst camshaft and lightened flywheel included revised front & rear springs which are simply Heavy Duty LC Torana S & SL front & rear springs and the 3.55:1 diff ratio which wasn't aimed at being used at Bathurst.
#6 yel327
  • 13,099 posts
Posted 18 June 2023 - 03:08 PM
It's an odd car too as L215021 was clearly assigned no cost centre (dealer code) and its zone office is marked as X, but it has an ADR plate which it shouldn't have ever had. These were only fitted to vehicles built for sale in Australia, there was no point and a waste of $ fitting one to a car built for export. I wonder if it was originally built for Australia and then moved to export?
Edited by yel327, 18 June 2023 - 03:09 PM.
#7 skap
skap
  • 1,057 posts
  • Name:Skap
  • Car:Mighty VN
Posted 18 June 2023 - 03:39 PM
Why did my old car also have its ADR plate?
I’ve seen others too.
#8 yel327
  • 13,099 posts
Posted 18 June 2023 - 04:14 PM
Don't know. It's an Australian Compliance plate, only goes on cars built for sale in Australia. Every 1/1970 onwards HT-HZ and LC-LX I've ever found that has been built in Australia for sale in NZ has just had either rivet putty or if a HQ-HZ commercial a GVW plate in that location. It says so in every Features Manual, see the LJ one page D-6 attached. The LJ sedan in Wanaka auto museum L212775 just had the ADR plate holes filled with the putty that was used in the early rivets. Why a few cars have one, dunno? Are they all XU1?
Attached File  LJ features ADR plate.jpg   96.5K   8 downloads
#9 jpxu1
jpxu1
  • 549 posts
Posted 18 June 2023 - 07:52 PM
Mmmm, stick and ADR plate on it so it can be included in the homologation numbers??
#10 S pack
  • 15,541 posts
Posted 19 June 2023 - 05:19 AM
If all the 9th month 72 XU1 found in NZ so far had an Australian Compliance Plate I could be tempted to think the same but alas they don't.
#11 yel327
  • 13,099 posts
Posted 19 June 2023 - 06:45 AM
A certain number of cars had to be sold in Australia for 1972 homologation if I remember correctly, regardless of whether they were made and/or assembled here or overseas? Not sure how an Australian Safety Compliance plate on a car sold new in NZ is going to make it countable anyway? The same thought did cross my mind though, but cannot see how a NZ car having that tag would fit even if it was one of the cars used for homologation.
Edited by yel327, 19 June 2023 - 06:46 AM.
#12 skap
skap
  • 1,057 posts
  • Name:Skap
  • Car:Mighty VN
Posted 19 June 2023 - 07:54 AM
In any case, that is two 9/72 LJ's that were sold new in NZ and had their ADR plates attached.....
Whilst it seems they should all have had the plate removed, it simply did not happen..
Why?  Appears none of us know.
#13 yel327
  • 13,099 posts
Posted 19 June 2023 - 08:09 AM
They weren't removed, they just weren't fitted in the first place. They had putty over the holes, same putty that went in the tag rivets. I've seen lots of them done that way. I should have taken a photo of the LJ at Wanaka. I took photos of its other tags.
My only guess is they weren't originally built for NZ sale, but were transferred after being built, to NZ sale. Not a dealer transfer but by GMH. Maybe not enough were allocated to NZ and all were sold prior to arrival so they grabbed a couple of Australian Stock Order cars and assigned them to NZ? Or its simply an error at the BAP.
#14 RedTaxi
RedTaxi
  • 61 posts
  • Name:Glen
  • Car:LX hatch
Posted 19 June 2023 - 10:31 AM
Iv'e definitely seen NZ new Toranas with and without the ADR plate. My LX doesn't have it. Just rivets in the holes and a bung in the middle.
#15 yel327
  • 13,099 posts
Posted 19 June 2023 - 10:59 AM
I've seen them with the ADR tags too, but all of those so far have been sent over from Australian stock, normally dealer stock. This car is a 000 X coded car.
#16 kudu
kudu
  • 1,443 posts
  • Car:LH SL/R 5000
Posted 19 June 2023 - 01:30 PM
As a note.. only from my observation... so not proof of any kind.... Buut I think nearly all XU1s I've looked at over here have had the 3rd ADR tag fitted. Because of this I always assumed that they must have fitted the tag on the line AND THEN decided which ones were to be sent across the ditch.
#17 Kockum
Kockum
  • 476 posts
Posted 19 June 2023 - 01:55 PM
Another 000 X  car with a compliance plate fitted sold new in NZ
11/72 XU1  - L222416 , ALJ 15979A
#18 LC Rusty
LC Rusty
  • 48 posts
  • Name:Russell
  • Car:LC GTR XU-1
Posted 19 June 2023 - 08:00 PM
My LC XU1 also has the ADR plate. Sold new NZ. I havnt seen one without it here
Edited by LC Rusty, 19 June 2023 - 08:01 PM.
