Just some Confirmation on Petrol and Brake line sizes
7 replies to this topic
#1 horsepowerhowie
horsepowerhowie
  • 80 posts
  • Name:Howie
Posted 03 July 2023 - 12:20 PM
Just need help on
what pipe sizes and material to run for Brake and Petrol lines
I'm running a stock ls3 with VE HSV brakes all round and drop tank (In built VE Pump)
i was thinking
Petrol- 3/8 supply and 5/16 return ( also not sure on material hard- stainless ect?) and ( braided?)
Brake- 3/16 or 1/4 ( also not sure on material-hard stainless ect?)
Just wanted some thoughts and experience what's best to do
Thanks Howie
#2 yel327
  • 13,099 posts
Posted 03 July 2023 - 02:02 PM
I reckon you'll be safe with 3/8" for fuel. I don't think you need a return with a VE pump? These are regulated at the MRA as far as I know. I'm running a VZ pump (due to height of the HK fuel tank) which is the same basic thing as a VE just taller. It only needs a single line to the engine, the return to the MRA comes straight off the outlet of the fuel filter which is located just forward of the tank. I'm just using standard steel bundy tube.
Datto will have a better idea on brake lines, but I imagine 3/16 would be fine. Whatever suits your master cylinder and calipers/hoses.
#3 76lxhatch
  • 7,156 posts
Posted 03 July 2023 - 02:43 PM
As above. Stainless won't be fun to bend - unless you really want it for show just ordinary bundy tube is much nicer to work with and perfectly adequate.
#4 dattoman
  • 16,472 posts
Posted 03 July 2023 - 08:23 PM
3/16 for brake
Some stainless is difficult to work with...I prefer not to you is
But there is a version of a bright steel 3/16 tubing out there that polishes up well
#5 Heath
  • 18,315 posts
Posted 04 July 2023 - 09:59 AM
3/16" for brakes.
If you ARE wanting to use stainless, I'll save you a lot of headaches easily. I struggled hard with Aeroflow's coiled stainless line and the shit kept on cracking during flaring, so I gave up on that.
I then settled on double annealed seamless stainless tube from Prochem for my brake lines.
Beautiful to bend, obviously a bit harder to flare. You need a good tool, and you need to lube it. But I had no problem getting good results with a bit of patience, cutting everything nice and square, de-burring inside and outside, etc.
Also, the stainless fittings are very expensive (I used SpeedFlow). I spent a bit over over $500 in materials (including braided flexible hoses) in addition to buying the tools. Then more again for the clutch hydraulics. But it's all very tidy.
Read from here onwards:
https://www.gmh-tora...atch/?p=1073572
#6 jpxu1
jpxu1
  • 549 posts
Posted 04 July 2023 - 07:57 PM
3/16" for brakes.
This sort of stuff is exactly why we have forums, and ours is the best .... long may it live on :-) :rockon:
#7 Rockoz
Rockoz
  • 3,969 posts
  • Name:Rob
Posted 05 July 2023 - 10:57 AM
With the harder stainless tube would it help to anneal the end before doing the flaring?
Ive been playing with some 16mm 316 stainless for coolant lines, and it was near impossible to use a hand bender on it until I did some annealing.
Once annealed it bent up quite nicely.
Rob
#8 horsepowerhowie
horsepowerhowie
  • 80 posts
  • Name:Howie
Posted 06 July 2023 - 03:43 PM
Appreciate the replies guys, solid advice.
