XU-1 nibless rims
31 replies to this topic
#1 4004757
4004757
  • 7 posts
  • Name:Mark Milburn
  • Car:LJ GTR XU-1
Posted 16 August 2023 - 10:54 AM
Inquiring as to availability of the XU1 nibless rims (4). My car came with the Sprint masters which are not period for a 5/72 car. Id like to see if any are around which are genuine and in VGC. Will need caps and dress rims and wheel nuts. Feel free to rip me off as I know they are hard to find.
My spare nibless is dated 3/72 from memory.
Edited by 4004757, 16 August 2023 - 10:57 AM.
#2 claysummers
claysummers
  • 3,643 posts
  • Name:Clay
Posted 16 August 2023 - 12:58 PM
I bought a set of xu1 caps, apparently, in fair condition 2 years ago for $100. Dress rings are available reproduction about $800 a set.
Edited by claysummers, 16 August 2023 - 12:59 PM.
#3 4004757
4004757
  • 7 posts
  • Name:Mark Milburn
  • Car:LJ GTR XU-1
Posted 16 August 2023 - 03:12 PM
I think the genuine rims are going to be the difficult items to source out. Someone would have them but don't want or need to part with them. The wheels are the only item/s I need to bring my XU1 back to all original which is my goal.
#4 skap
skap
  • 1,111 posts
  • Name:Skap
  • Car:Mighty VN
Posted 16 August 2023 - 03:16 PM
Last single one I saw was $700 on ebay.
Just get standard rims and have the cap retainers knocked off on a lathe.
The dress rims, caps and nuts will cost you a small fortune as it is.. unless ya getting repros of those in which case why bother with genuine rims?
#5 4004757
4004757
  • 7 posts
  • Name:Mark Milburn
  • Car:LJ GTR XU-1
Posted 16 August 2023 - 03:27 PM
I'm one of those idiot rivet counters so would happily pay whatever for the unmolested nibless rims etc.
#6 skap
skap
  • 1,111 posts
  • Name:Skap
  • Car:Mighty VN
Posted 16 August 2023 - 03:30 PM
In for a penny.
Best of luck, will keep an eye out :)
#7 LCK186
LCK186
  • 399 posts
  • Car:71 CK
Posted 16 August 2023 - 07:35 PM
 Hi i have a friend in newcastle area who does have a full set of genuine xu1 nibbless rims that have been blasted and powder coated, send me your ph no and i will pass it on
#8 Shiney005
  • 9,639 posts
Posted 17 August 2023 - 08:23 AM
Just over half of what L34 and A9X rims are making these days.
#9 yel327
  • 13,678 posts
Posted 17 August 2023 - 08:25 AM
They should be Laurie as there were a lot less of those made.
#10 4004757
4004757
  • 7 posts
  • Name:Mark Milburn
  • Car:LJ GTR XU-1
Posted 17 August 2023 - 02:09 PM
PM sent
#11 4004757
4004757
  • 7 posts
  • Name:Mark Milburn
  • Car:LJ GTR XU-1
Posted 22 August 2023 - 10:07 AM
Still looking if anyone has any.
#12 yel327
  • 13,678 posts
Posted 22 August 2023 - 10:51 AM
Can you get some made using Commodore L centres in original LJ bands?
#13 claysummers
claysummers
  • 3,643 posts
  • Name:Clay
Posted 22 August 2023 - 07:41 PM
Or get some stock ones and shrink/grind the nibs out.
#14 SPONGY
SPONGY
  • 30 posts
  • Name:Warren Curtis
  • Car:LJ Torana
Posted 22 August 2023 - 09:21 PM
And how do you make the wheel centres thicker ?
#15 yel327
  • 13,678 posts
Posted 23 August 2023 - 06:36 AM
For a road car why would it matter? I'm talking about the instance where you cannot buy any but want them to look right.
#16 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 August 2023 - 09:46 AM
You can't notice much looking at them, apart from mainly the welding on the back.
#17 4004757
4004757
  • 7 posts
  • Name:Mark Milburn
  • Car:LJ GTR XU-1
Posted 23 August 2023 - 04:05 PM
Rivet counter remember. Has to be the genuine rims.
#18 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 23 August 2023 - 07:48 PM
As below.
https://www.ebay.com...RMAAOSwFAZk4ADn
#19 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 27 August 2023 - 07:18 PM
So these are $1,800 & not welded on the back, like an original xu1 nibless wheel ?
#20 claysummers
claysummers
  • 3,643 posts
  • Name:Clay
Posted 27 August 2023 - 07:39 PM
They be spot welded. Look like a bit of an offset for 5” rims?
#21 S pack
  • 15,731 posts
Posted 27 August 2023 - 07:58 PM
Correct, not welded because they are not nibless rims. They are std 13 X 5.5" GTR rims that have had the nibs pressed back down and machined to clean up the surface to look like nibless rims.
Edited by S pack, 27 August 2023 - 07:59 PM.
#22 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 27 August 2023 - 08:15 PM
Well, instead of him calling them replicas, maybe he could call them, sort of similar, because at $1,800, if i looked at buying a set of replica wheels. I would expect them to be welded on the back. $1,000 over priced, let's face it !
#23 yel327
  • 13,678 posts
Posted 27 August 2023 - 08:22 PM
In reality probably no different to people cutting the centres out of L34 rims and welding in HK centres. Or vice versa. To make them look right. Lot of $ though.
#24 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 27 August 2023 - 09:20 PM
If they were, fully welded and unpickable, then that would be fine. But they're just not close enough at $1,800, that's almost 2 grand for a set of slightly modified basic torana rims. 2 grand is a fair bit of coin.
#25 Bruiser
Bruiser
  • 863 posts
  • Name:Bruce
Posted 27 August 2023 - 09:29 PM
Jeezus how much do they want for a set of the real thing then?
I got a set 35 years ago to replace some chromies I smacked up on a kerb, trim rings, caps, nuts and all
Couldn’t wait to get rid of them, crappy black boring things, it had to be mags
Wish I still had them now
Edited by Bruiser, 27 August 2023 - 09:32 PM.
