As Dave says, there was only ever really two red heads with minor tweaks along the way (such as rocker arm change and other such things):
The big engine head - as used on 179, 186 and 202. To create the low comp 186 and 202 they dished the pistons (larger dishes on 202).
The small engine head - as used on 130, 138, 149, 161 and 173. To create the low comp small engine (138 to 173) they used the big engine head, plus dished pistons on 173 only.
Most of you all know that in general the rocker gear changed on the 161-173 and 186-202 transition although from memory the 130 and 138 spanned that change.
XU1 aside of course as those heads were not standard production red heads.
