It’s got a lumpy cam in it. The Edelbrock 600 carb has the electronic choke disabled (choke is wide open all the time).
When I got the car, the initial timing was set at about 25 degrees advanced. This seemed high to me to I lowered it to 16 and still can’t get the engine to idle smoothly.
At 16 advanced, the car idles too low so I have to turn up the idle screw so much that I believe the transfer slots would be too far open. As far as I know, they say if you need to open up the transfer slots too much, the timing needs to be more advanced.
Is it possible the engine really does need that much initial timing (25)?
If the engine really does need 25 degrees advanced to idle right, what would usually be the ideal total timing?
Would it still just be around 36 total?
Is it ok to have a distributor curve like this?
Edited by Johno, 02 October 2023 - 04:09 PM.
