Just trying to familiarize myself with what 'normal' is as I get this car back to semi-regular use on the road.
Just a 202 and Trimatic with thermo fans on it. At full op temp she sits right about middle of the gauge (in the middle of the "normal" band). My thermo controller has its own temp sensor which I've mounted in the radiator upper tank beside the coolant inlet. Mid gauge on the cluster is resulting in coolant temps of 90 degrees.
In principle this doesn't seem bad but I remember from the old days my UC used to happily sit on the low mark of normal on the gauge (coolant temp would be about 75 there I think). What do people regard as normal ? Am I just used to manuals (this is my first auto) and they run cooler or should I be looking to fit a lower temp thermostat given we're still a long way from full summer heat.
Matt
