Edited by hanra, 22 October 2023 - 10:01 AM.
Big Nut Lid Seal
Posted 22 October 2023 - 10:00 AM
Posted 22 October 2023 - 12:11 PM
Posted 22 October 2023 - 07:03 PM
I'll check what brand ours are tomorrow
Posted 22 October 2023 - 08:01 PM
Posted 23 October 2023 - 08:11 AM
I did a brake fluid flush on the weekend and strangely enough, I had fluid trapped between the lid seal and the underside of the lid. How did it get there? And how did it not leak out....?
Posted 23 October 2023 - 09:09 PM
The 2 I have in stock have what looks like HOLDEN on them
Will try to get a clear pic
Posted 24 October 2023 - 08:13 AM
Save them for me Neil. I will bring my brake parts down on Friday for you to give the once over.
Posted 24 October 2023 - 05:10 PM
Had the same problem Brad- hopefully Datto or someone may know how?
And hopefully I can find the post ! These jumbled up replies are doing my head in.
Posted 24 October 2023 - 05:19 PM
No leaks around the edges of the M/C otherwise.
Posted 24 October 2023 - 06:04 PM
When you bleed the brakes by pumping the pedal fluid squirts up out of the master. Maybe there's a split in the rubber??
Lesson I learnt is never leave the cover off while bleeding.
Marty
Posted 24 October 2023 - 06:13 PM
I gravity bled the brakes and also gave the pedal a very very very slow press/retract with the lid off.
Yes, I can see if you go too quick it will squirt right up and cause a major headache.
Posted 24 October 2023 - 06:45 PM
I will send one over if I get them Brad.
Posted 24 October 2023 - 07:03 PM
Posted 24 October 2023 - 08:58 PM
I have these 2 on my desk
We buy them from MCX in QLD
They may have sourced the original mold
Hence the HOL you can see... but not the rest of the word
lid seal.jpg 172.79K
2 downloads
Posted 24 October 2023 - 09:33 PM
Laurie, makes sense for me to grab one from this side of the country if they stock them.
Posted 26 October 2023 - 12:53 PM
Neil,
Can you comment as to why I may have found brake fluid between the seal and the lid but not outside of the M/C at all?
It was trapped in there quite well.
Posted 26 October 2023 - 01:10 PM
Posted 26 October 2023 - 01:32 PM
The tin lid does not have any breather holes.
Posted 26 October 2023 - 01:34 PM
#21
Posted 26 October 2023 - 01:40 PM
Posted 26 October 2023 - 01:42 PM
Funnily enough I see what looks like a hole at the rear of the lid....? If it was a hole, there would have been fluid leaking from that....? I need to have a proper look when I get home.
#23
Posted 26 October 2023 - 01:56 PM
#24
Posted 26 October 2023 - 02:33 PM
#25
Posted 26 October 2023 - 07:15 PM
