Gday All
Still got bad a fuel smell in the cabin whilst driving.
I have had the Rochester rebuilt so it virtually new. Its been tuned but I reckon its still using too much fuel but more on that later.
I have replaced the sender unit (and gasket) as the old one appeared to be cracked where the main fuel line goes in.
I propose to do the following:
1. Check the fuel cap gasket. Its got a Valiant Charger flip top cap, looks cool but dont know if its sealing properly.
2. Check the vent line (again), it should discharge to atmosphere somewhere above diff correct? I will also check it for blockage.
3. Check the fuel line from the tank to the carry (again).
4. Block all holes in the firewall, there is one un-grommet 12-15mm hole I can see. I will plug it and any other ones I can find.
5. I read somewhere (here I think) that someone had fuel smell problems and they adjusted the back of the bonnet down so it seals properly. Mine sits up a bit, I suspect its been set up that way so the air cleaner does foul the inside of the bonnet. It makes sense I guess, if it isn't sealed properly, air will go from the engine bay into the air grills in front of the windscreen right?
Have I missed anything ? That is, any other suggestions?
Re the fuel usage, pre carry rebuild, it was using around 52 L/100km (based on figures from short runs.
Since the rebuild, its down to 38 L/100km which is still too high for a fairly standard Holden V8. I intend to get the bloke who rebuilt the carby to retune it on his machine. The carby was fitted and tuned by my mechanic but I don't think he did a very good job with the tune.
Any thoughts?
Nanbar
