Bending Headers
12 replies to this topic
#1 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 20 November 2023 - 11:14 AM
I have a set of Castle Headers on my LX, and they fit okay in a tight space, but I am wanting to bend them 5mm here and there for better clearance (p/s crossmember bolt, steering cotter pin on D/S) so I can start on the exhaust. Taking them out means half pulling the engine out, so I want to do in situ, also to make sure I am bending right.
They are already ceramic coated unfortunately, however the coater said heating to bend is no problem, as long as I do it little by little.
My question is, as I don't have any Oxy set up, do you reckon I will get the heat I need from one of these Propane torches?
Attached File  Screenshot 2023-11-20 at 12.11.16 pm.png   530.39K   5 downloads
#2 RallyRed
  • 8,179 posts
Posted 20 November 2023 - 12:30 PM
Hi,
My very limited experience in this is -
1. Even with oxy,it's hard to get enough heat in enough places, to effect the bend you want. i.e you may get good heat into 2 pipes but the other two cool ones will fight against your bending action.( assuming the collector ties them all together).
2. Make sure you have them bolted up to the head, as some of your bending stress may end up at the manifold flange, thus leaks occur.
If you just want to put a " dint" in them to clear a bolt head or whatever, that's pretty easy.
Lke I said, just my limited experience
Edited by RallyRed, 20 November 2023 - 12:32 PM.
#3 yel327
  • 13,717 posts
Posted 20 November 2023 - 12:39 PM
Thos little bottles and heads are one of the best investments you'll ever make, but as Col says may not give you enough heat quick enough to heat up multiple spots. It will certainly heat up individual bits well though. I have found them invaluable for stuff like soldering lugs onto big cables especially when in a trench and want to use the cable lugs for pulling a cable through a conduit using Paramatta rope (did this recently using the Ram's remote operated winch through a few pulleys). Also good for unfreezing stuck stuff, like getting the taper seat wheels off my Greenfield mower.
#4 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 20 November 2023 - 12:48 PM
As above, good for soldering and unfreezing bolts and such. You can only really anneal a bit and still need quite a bit of bending force.
#5 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 20 November 2023 - 12:50 PM
Mind you, steel header pipe is probably easier to get concentrated heat in to than the copper I've been playing with.
#6 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
Posted 20 November 2023 - 01:31 PM
That's awesome fellas, thanks. I will just be heating/bending a two-pipe section after the main collector (not four), so it sounds like it might be worth a try at least. My other option is to just pack the car off to an exhaust shop, but I really want to do it myself for whatever silly reason. Ha ha.
Noted on using it for other things, too.
Appreciate the input.
#7 Shiney005
  • 9,712 posts
Posted 20 November 2023 - 03:46 PM
It will have a much larger flame than an oxy for the same heat. It will be hard not having the floor hot enough to melt your carpets.
#8 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
Posted 20 November 2023 - 05:47 PM
Thanks Shiney, good to know - no carpets in her, so now's the time!
#9 Bruiser
Bruiser
  • 867 posts
  • Name:Bruce
Posted 20 November 2023 - 07:26 PM
I remember reading someone having a go at this using strategically placed blocks of wood (or steel) in one spot
and using the twisting wire fence technique slowly with heat to get stracktors to get them to bend a bit.
Might have even been with the engine running amount of heat, but memory isn’t quite that good
Wouldn’t have been wood in that case
Sounds like putting some strain on the pipe(s) in the right spot and heating them up is the go
Hope you manage to get it done somehow
#10 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
Posted 21 November 2023 - 06:45 AM
Yeah, I have heard of people just running the engine until they are hot, then swinging on them with a big bar. I am hoping for a little more precision than that, but honestly, whatever works. Thanks mate.
#11 Heath
  • 18,401 posts
Posted 21 November 2023 - 09:26 AM
Perhaps put your breathing & hearing apparatus on, strap down the front wheels, side step the clutch in third with a clamp on the accellerator and start smoking the garage out. Might be a bit hard to get a big bar into the collector when it's W.O.T. on the limiter (not sure; never tried) but at least you'll get some proper heat into the pipes.
The neighbours may not like this method.
#12 Shiney005
  • 9,712 posts
Posted 21 November 2023 - 11:58 AM
Attached File  m3_engine_dyno_987.jpg   32.81K   4 downloads
#13 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
Posted 21 November 2023 - 07:14 PM
