Oil Sender
8 replies to this topic
#1 Flaming Skull 57
Flaming Skull 57
  • 112 posts
  • Name:John Harris
  • Car:LC Torana "Gilberts Stinger"
Posted 25 November 2023 - 04:24 PM
Hi All
Can you put a oil sender unit in Petrol, Metho, Turps, Thinners, etc, to clean the insides? Not sure what's inside it - rubber?
My LC sat in a garage for 15 years, so the oil would have solidified.
The gauge is slow to respond, and I think its clogged.
John
#2 S pack
  • 15,541 posts
Posted 25 November 2023 - 04:53 PM
I would use Kerosene to wash it down however I don't know if any oil actually goes inside the sender unit. Never pulled on apart but I expect there will be some sort of actuating piston upon which the oil pushes.
Edited by S pack, 25 November 2023 - 04:54 PM.
#3 claysummers
claysummers
  • 3,334 posts
  • Name:Clay
Posted 25 November 2023 - 05:59 PM
I'd be careful of using thinners to be on the safe side. I would put it in a sonic cleaner in kerosene or similar. I do use petrol in the sonic cleaner, but always nervously. A mate puts the parts in zip lock bags with petrol, and water on the outside.
#4 Flaming Skull 57
Flaming Skull 57
  • 112 posts
  • Name:John Harris
Posted 25 November 2023 - 06:08 PM
Thank You
I will try Kero. If all else fails I will buy another one.
#5 Flaming Skull 57
Flaming Skull 57
  • 112 posts
  • Name:John Harris
Posted 26 November 2023 - 08:09 AM
FYI
Electric sensor units
Sensor units for electric gauges work by sliding a wiper up a curved blade of known resistance. The wiper is moved by a diaphragm which keeps the sender oil-tight.
#6 S pack
  • 15,541 posts
Posted 26 November 2023 - 09:15 AM
FYI
Thanks John. Learn something every day.
#7 Flaming Skull 57
Flaming Skull 57
  • 112 posts
  • Name:John Harris
Posted 27 November 2023 - 02:38 PM
I took the Oil Sender off this morning and as per advice I soaked it in Kero in a sealed container and gave it a good shake.
Then taped in on the workbench and a spray of compressed air. I was surprised with the old oil that came out with each tap, although only a few drops each time. But it added up.
Did this many times over.
Fitted it again with thread tape and started the engine. Well, instant response at the gauge. Normally I have to wait many seconds before the gauge moves.
Gave her a rev and instant response on the oil gauge. Normally it doesn't really move unless I'm on the motorway at speed.
Thanks Dave and Clay
#8 S pack
  • 15,541 posts
Posted 27 November 2023 - 06:13 PM
Far-King ACE mate :spoton:
#9 claysummers
claysummers
  • 3,334 posts
  • Name:Clay
Posted 27 November 2023 - 09:19 PM
Cheers John.
