proportioning / combination valve
21 replies to this topic
#1 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 06 January 2024 - 04:11 PM
        ive tried to find the answer myself with no luck ........ 1976 lx torana aftermarket master / proportioning valve and disk / disk setup ..... master is 1inch .......i  supposably have a disk / disk prop valve but have a low pedal great braking but i hate the free travel ....... my question is what is the internal differences between disk / drum and disk / disk ....... i have both but one has a removable front plug .....( supposed to be disk / drum ) and the disk / disk only has removeable fitting for rear brake line. ive searched online and have two trains of thought and both relate to the disk / drum prop valve ...... one theory is to increase the spring pressure in the front ..... theory no 2 is to take out the piston in the rear part of the prop valve ...... im confused to what the correct answer is ...... any help would be appreciated
#2 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 06 January 2024 - 05:09 PM
May sound funny but make sure your front wheel bearings don't have any excess play in them. This can contribute to low pedal.
#3 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 07 January 2024 - 07:24 AM
claysummers ........ all of the driveline is less than 500 kms old, thankyou for your suggestion ........
#4 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 07 January 2024 - 07:29 AM
i have removed the master to bench bleed, ive re lubricated all of the caliper slides ...... i dont remember how many times over the last 6 months that i have bled the brakes. but i cant solve the issue of the free travel ....... have vt front disk and vs rear disks .... so im back to the prop valve as its the only part trhat im not sure about ...... all suggestions greatly appreciated
                                   mark
Edited by marko1au, 07 January 2024 - 07:31 AM.
#5 claysummers
claysummers
  • 3,336 posts
  • Name:Clay
Posted 07 January 2024 - 08:58 AM
Still worth checking wheel bearing play. Specially if new. Inspector found excess play in my freshly built car after bed in. Another of my cars the brakes would go to the floor first application as the play in the pads was taken up due to loose wheel bearing. Don't discount it, eliminate it.
#6 yel327
  • 13,104 posts
Posted 07 January 2024 - 09:14 AM
Make sure the reaction disc hasn't fallen off inside the booster. Having it missing creates a long pedal.
#7 Indy Orange
Indy Orange
  • 2,850 posts
  • Name:Paul
Posted 07 January 2024 - 11:01 AM
Certainly got a reaction out of me! Had to take the brake booster off and shake it out of the booster ,hours of fun!
#8 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 07 January 2024 - 01:03 PM
booster is less than 6 weeks old ....... i had it rebuilt incase it was the issue .......
claysummers ...... i will check the wheel bearings ....... thankyou
#9 LJ RB30
LJ RB30
  • 975 posts
  • Name:Trevor
Posted 07 January 2024 - 02:37 PM
If you have VT calipers on the front then you will need a VT master cylinder as they are a "Fast fill" unit.
The VT master are not just a 1" master cylinder but a 1" that supplies the rears AND a 1 1/4" to supply the fronts.
This is due to the  VT having 2 spot calipers requiring more volume of fluid.
The VT calipers will take more of the fluid and pedal travel before you get any effective braking.
Hope this makes sense
#10 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 07 January 2024 - 03:34 PM
LJ RB30.......... i had the feeling that would be the issue, food for thought then ......... so its either the calipers or master i have to change
claysummers ........ bearings are good ........ but again thankyou
#11 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 07 January 2024 - 04:38 PM
LJ RB30 .....in my excitement i forgot to thank you for that information
Edited by marko1au, 07 January 2024 - 04:38 PM.
#12 LJ RB30
LJ RB30
  • 975 posts
  • Name:Trevor
Posted 07 January 2024 - 08:28 PM
No worries mate.
#13 dattoman
  • 16,472 posts
Posted 08 January 2024 - 09:03 PM
Ok lets go back a step
What master is on the car ?... replaced when fitting the disc rear ?... is its to suit 4wdisc ?
What valve are you using... as its unlikely to be a thing.. .what what did it come off ?
Are you sure they are VT calipers ?... any casting #'s on them ?
Got any pics of setup ?
Yes check the booster to make sure the reaction discs has not fallen out
It is possible to adapt a VT style master... but lets check some other things first
#14 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 09 January 2024 - 02:21 PM
dattoman........
master is an aftermarket 1 in bore to suit 4 wheel disks ........ prop/ combination valve also aftermarket to suit 4 wheel disk ..... booster recently re built using commodoe booster to suit torana bolt pattern .... pics to follow and the vt calipers i will take pics of this afternoon and send them to you.
                      Mark
#15 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 09 January 2024 - 03:12 PM
dattoman ....... email sent
#16 dattoman
  • 16,472 posts
Posted 09 January 2024 - 09:30 PM
First thing I'd do is check the booster pushrod to master clearance
But it may be a displacement issue with that master as mentioned
You can buy a spacer bracket to bolt to H series/Torana booster to take the VT master
https://www.ebay.com...6kAAOSw8HpgSK2u
This may be an option if its a displacement issue... but will need to repipe car (metric fittings)
Have you tried clamping the rubber hoses (all 5 ) to determine you have a good high pedal to start with.... and dropping a clamp at a time to see if the issue points to a particular wheel ?
#17 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 10 January 2024 - 11:56 AM
push rod on booster was setup by the booster repairer, i gave him the master to setup correctly. ......... if we are sure we need the vt master ive already been quoted for the re pipeing ......... havnt clamped the rubber hoses yet but will do to confirm the issue ....... thankyou for your assistance ....... will check out the adapter you suggested
#18 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 10 January 2024 - 11:59 AM
clamp off all 5 ......... i only count four .......
#19 dattoman
  • 16,472 posts
Posted 10 January 2024 - 09:45 PM
1 to each caliper
1 body to diff
#20 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 11 January 2024 - 03:09 PM
i forgot that one ......... thankyou
#21 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 12 January 2024 - 01:43 PM
will test the displacement theroy on sunday
                    Mark
#22 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 14 January 2024 - 04:48 PM
LJ RB30
thanks for the information and i feel it is a distibution issue ....... if i have the rear calipers and body hoses clamped i still have the excessive free play ........ if i clamp both front calipers the free play is noticebly less ...... there is approx 8-10 mm difference between clamped and un - clamped front calipers ..... this measurement is taken between the brake light switch bracket and the pedal it self .......im not sure what the difference is at the pedal pad but ill assume probably 50 mm or more
                             Mark
