SU Needle selection
24 replies to this topic
#1 salamiman
salamiman
  • 128 posts
  • Name:Bruce
  • Car:LJ 2 door tribute
Posted 18 January 2024 - 09:34 AM
Hi All,
Calling on the SU gurus please.
Trying to choose some new needles for an approx 200hp 202.
They are HS6s & am running TLs ATM, 12 flats down(2 full turns) @ 1100 rpm idle.
The TLs behave very well down low but the engine runs out of steam up top.
AO7 is recommended
I'm betting the AO7 would perform better up top, but it looks like the AO7 is leaner down low.
Should this be a concern & will i have enough thread on the seats to make the AO7 richer down low?
I found another needle BDL, has an almost perfect curve a the start to match the TL & a little more up top than the AO7.
Can anyone explain whats happening with the fueling curve in the high rpm with the BDL as the curve keeps going(see photo), is it a longer needle?
Thanks Bruce.Attached File  gmh Capture.jpg   36.94K   2 downloads
#2 claysummers
claysummers
  • 3,351 posts
  • Name:Clay
Posted 18 January 2024 - 02:47 PM
No expert by any means. Only about 3/4 your horsepower from my 186 bore 179. I’m running OA7s and red springs in my HS6s on a stock head [email protected]”, 109 separation, 0.435” lift. Needles and springs were advised by Bruiser and pretty spot on. He swapped me the needles for a set of OA6 richer ones.
I’m just wondering if you want richer needles for that hp? As I said I’m no expert.
#3 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 18 January 2024 - 04:24 PM
MMM Not sure clay, hopefully someone with a little more experience with these carbs might chime in.
The AO7 needle recommendation was only from reading on our site.
The AO6 may be better??
#4 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 18 January 2024 - 09:19 PM
Been a long time since I had the HS6 on one of my engines, but the engine was making about 190hp using AO7 needles, AO6 was too rich in my case. How are you tuning? dyno, O2 meter, colour tune etc.
#5 Bruiser
Bruiser
  • 699 posts
  • Name:Bruce
Posted 18 January 2024 - 09:40 PM
It’s a tough one to figure out, I went down the same path as you, and went with ones other guys on here
had used as the only starting point I could see.
The TWs Clay now has were reccomended for a motor of very similar spec to mine at the time, and my motor hated them
Seemed lean up top, and afr meter confirmed it. (TW are leaner down low and richer up top than your TLs )
OA7, SN, TP and (Ksomething) also came up as candidates.
After the change to bigger cam and more head,
I started reprofiling the set of BBFs that came my carbs, real carefully
Aimed at OA7 size for starters and gradually rich ended up the thin ends bit by bit
Ended up putting in Clay’s OA6s which aren’t far off
The biggest learn from sanding down my own needles was
How much difference a a few thou makes to the afr meter reading
Most people say the often recommended RH needles are super rich
Your motor with crow35803(?) cam and around 200 (rear wheel hp?)
Would probably like something between oa7 and oa6
Don’t think they make 0A6.5 needles
The BDL has 2 extra station measurements listed, so it must be longer
Those were TW needles I swapped with you, Clay
#6 claysummers
claysummers
  • 3,351 posts
  • Name:Clay
Posted 19 January 2024 - 06:41 AM
Uh huh, thanks Bruce.
#7 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 19 January 2024 - 08:48 AM
Tuning At idle, old school-Best RPMs VAC Gauge.
OA7 Might work i reckon, as I will prob have to lower the jet more to get best idle with them, as they are leaner at the start.
I have read that doing this will richen the mixture over its whole range.
If I need more fuel up top later, I could always play with them a little as you did Bruiser.
Any suggestions on a reasonably priced oxygen sensor & gauge.
If im looking to get the most out of this thing it would be a good investment I reckon.
#8 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 19 January 2024 - 09:56 AM
I run an LM2 O2 meter. You won't tune it properly without one.
#9 hanra
  • 10,839 posts
Posted 19 January 2024 - 10:16 AM
Dont forget to consider the weight of your dashpot oil and dashpot spring colour.
#10 Bruiser
Bruiser
  • 699 posts
  • Name:Bruce
Posted 19 January 2024 - 06:18 PM
I have the aem 30-4110ns afr gauge
Found the cheapest way at the time was buying the one
without the o2 sensor and getting that separately.
Took a punt on a cheaper one, too and it all still works fine a year later.
That needle was a KU by the way
#11 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 20 January 2024 - 06:04 PM
reckon I might buy one of these on fleabay, should give a good starting point, seeing i dont have a dyno in the back yard.....
Once youve got it dialled in, you prob dont need the set up anymore.
$125 bucks sounds good to me
52mm AFR O2 UEGO Wideband Air Fuel Ratio Gauge Kit 30-4110 LSU 4.9 Probe Sensor
Next question would be, on 98, what AFR @ WOT should I aim for for max power?
Edited by salamiman, 20 January 2024 - 06:06 PM.
#12 warrenm
warrenm
  • 2,107 posts
Posted 20 January 2024 - 09:27 PM
12.6-13.1 on petrol(95 or 98) at wot is good, idle afr is what ever the engine is happy with, could be 14.7 but could be 13.5.
#13 hanra
  • 10,839 posts
Posted 20 January 2024 - 10:09 PM
I ended up borrowing a friends LM-2. It really made the tuning process much easier.
A lot easier than trying to drive, hold a mobile phone. Hold the LM-2. Change gears. Keep the LM-2 in view of the phone for review at a later time…..
https://youtu.be/JQv...-k9cpW_1hIzCboH
#14 rodomo
  • 18,001 posts
Posted 20 January 2024 - 10:12 PM
 Attached File  Me tuning Gary's SU's.jpg   314.9K   6 downloads
#15 hanra
  • 10,839 posts
Posted 20 January 2024 - 10:49 PM
I use gunsons for balancing.
#16 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 21 January 2024 - 10:33 AM
Whers the ear Funnel?, high tech amplificaton!!!!
#17 rodomo
  • 18,001 posts
Posted 21 January 2024 - 09:59 PM
It's an art form.
#18 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 22 January 2024 - 12:07 PM
It's an art form.
Too True, I reckon most people who complain about triple SUs dont or cant get the balancing right.
This works pretty well too, the theory makes sense.(Btm section of the article).
Got it from the idiots guide to tuning SUs.
I use the centre carby as the master & tune the others airflow to it.
Use s/core plastic coated copper elect wire, it wont scratch the insides of the carbies.
#19 warrenm
warrenm
  • 2,107 posts
Posted 22 January 2024 - 09:26 PM
The 1st reason a lot of people can't tune SU's, is the throttle shafts are usually worn out,
2nd is they try to set the idle too low, ie. bigger cam & try to set the idle at 600 or 700 revs.
#20 claysummers
claysummers
  • 3,351 posts
  • Name:Clay
Posted 22 January 2024 - 09:49 PM
That is gold salami. I previously borrowed a mates synchroniser as in the picture above and now bought an edelbrock one for $80. The trouble is having to take off the filters, which the rear one is a pain to replace in my car. So the wire method would be easier.
I reckon those that have trouble tuning have leaky throttle shaft bushes. It is the first thing to look at on any throttle body of age.
#21 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 23 January 2024 - 07:33 AM
Tried a few diff methods over the years & this seems to be one of the easiest & as you say can be done with air cleaners on!
#22 warrenm
warrenm
  • 2,107 posts
Posted 23 January 2024 - 09:37 PM
Taking the air cleaners off once a year shouldn't be a hassle, you have to clean/replace etc.
#23 claysummers
claysummers
  • 3,351 posts
  • Name:Clay
Posted 23 January 2024 - 09:41 PM
It is a bit of a pain in an FB engine bay Warren, that’s all. I doubt I would change the filters yearly. The car just doesn’t get that much use. I’ve got a new head going on soon so it will come off then.
#24 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 24 January 2024 - 09:03 AM
True.
#25 salamiman
salamiman
  • 128 posts
  • Name:Bruce
Posted 24 January 2024 - 09:23 AM
Tried a on road test whilst waiting for the afr gauge.
Whilst driving, i tried the chokes, lowering the jet by various amounts.
Did this at WOT at 3, 4 & then 5000rpm in 3rd gear.
So WOT held for a couple of seconds, pulled the choke to different positions on separate pulls.
Found no noticeable increase in power?
You can feel resistance when pulling on the jets & have them set that they pull down 5mm max.
Only when the jets were nearly fully down, did i notice a loss of power.
But never an increase.
Too rough to give any indications?
