how to wire a electric choke on a holley?
_UCV80_
Posted 07 September 2006 - 09:40 PM
Anyone wired one up b4.. i have one on my 390 and would like to wire it in.. does it need constant power to it?
cheers,
nathan
_devilsadvocate_
Posted 07 September 2006 - 11:05 PM
If you have fitted a 12V ignition you could take it directly of the +ve coil wire.
If conventional ignition:
Take the power off where the thick pink wire meets the fuse panel. This connection unfortunately gets all its power through the ignition resistance wire when the motor is cranking , so the choke needs to be able to stay working with only 8V or so applied, however, it will get 12V when the ignition is first turned to on and should still function even if the voltage drops to 6 or 7V through the resistance wire and return to 12 V when the motor is started. If you have a LX or UC there are several extensions of this pink wire under the bonnet, one that previously powered the antidieseling solenoid would suffice.
If the choke wont hold on while cranking, then youll never get started, the way around this would be to fit a relay that is switched by the +ve coil wire.
Posted 08 September 2006 - 03:39 PM
If it wont work with 8 volts it will just stay on longer..but only a tiny bit longer.
_UCV80_
Posted 08 September 2006 - 04:04 PM
I dont use a pink wire.. i use a Wire staight from battery to +on coil via a switch and fuse.
So will this wire be ok? its 12V
so i just piggy back a wire from that one to the choke, or should i wire it into the accesories...
The engine starts all the time, first go even when cold.. its just wen cold it dies at the lights and stop signes, its quite dangerous.will the choke will solve this problem?
Thanx
_EXLXSL_
Posted 08 September 2006 - 06:47 PM
14. Connect the long wire from the kit to the positive choke cap terminal marked (+). Connect the other end of the wire to a
fused ignition activated 12V source. The choke cap should only get voltage when the engine is running. Check your
voltage source with a voltmeter.
WARNING: The distributor side of the coil is not a 12V source. Connecting the choke cap to the ignition coil will
result in unacceptable choke operation and possible engine misfiring resulting to possible engine
damage. Do not connect the choke wire to the coil!
_UCV80_
Posted 08 September 2006 - 07:04 PM
So it must have to connect to accesories... cant wait to see this choke work
cheers,
nathan
_devilsadvocate_
Posted 08 September 2006 - 07:42 PM
EXLXSL, I dont think you read what I wrote carefully. I suggested to take the power off the +ve side of the coil, which is not the distributer side(thats the -ve side), the +ve side will in ToranaZ case have a constant 12V supply in both the on position and the start position.WARNING: The distributor side of the coil is not a 12V source. Connecting the choke cap to the ignition coil will
Wiring it the to accessories terminal may work when the engine is running, but remember you have to get it started first. Not having the choke operation in start mode could be problematical, depending on whether power is used to open or close the choke, for hot or cold starts or both! The accessories terminal goes dead when you crank the starter, so it is not really suitable for any thing that is required for the motor to run. The accessories position on the ignition switch is typically used when you run the radio etc when the car is parked, if you connect you choke to it, then there will be a unnecessary current drain in this application.
Torana Z, the +ve terminal of the coil will be your best option since you have already have the 12V ignition. I have used this setup myself, having an electric choke on a ww strommy.
Edited by devilsadvocate, 08 September 2006 - 07:50 PM.
_devilsadvocate_
Posted 08 September 2006 - 08:03 PM
Just took this in, is this roadworthy/legal?I dont use a pink wire.. i use a Wire staight from battery to +on coil via a switch and fuse.
_UCV80_
Posted 08 September 2006 - 09:43 PM
Going to wire it up soon
I guess it is rwc haha whos to know, the cops wont know unless they try to steal the car and fail.
Thanx again!
,nathan
_EXLXSL_
Posted 09 September 2006 - 07:21 PM
Not having a go or nothing.
That information was copied from www.holley.com. I was just passing on what Holley about wiring an electric chole on one of their carbies. It was THEIR warning afterall.
_devilsadvocate_
Posted 09 September 2006 - 10:37 PM
ie "Sorry Devils, you did say the +ve terminal...my misunderstanding/mistake"
.........nothing wrong with the Holley site advice(about not connecting the choketo the distributor side of the coil), why blame them for your error?
Edited by devilsadvocate, 09 September 2006 - 10:47 PM.
_EXLXSL_
Posted 09 September 2006 - 11:14 PM
All the info from my post was as copied from the tech information on an electric choke from the Holley website. I just thought if may have been of some use.
_devilsadvocate_
Posted 10 September 2006 - 06:24 AM
