ID Torque Converter
7 replies to this topic
#1 LXCHEV
LXCHEV
  • 3,637 posts
  • Car:'76 LX - 383 Chev
Posted 17 May 2025 - 07:34 PM
My Dad has this torque converter, left over from a previous project. Firstly - I'm trying to confirm what it suits. Secondly - what it's worth to sell for him.
Background story:
Dad had an LH Torana with 253 V8 and Trimatic. Sold the car. The new owner had all sorts of plans and Dad continued helping him work on the car for quite some time. New owner started collecting bits. He purchased a mild 308, and he purchased this torque converter. It was delivered from Underwood in QLD. I'm assuming it's a mild converter to suit the Trimatic, but I'm guessing. No idea if it's been re-co'd or just second hand. It measures at just under 12" diameter. Guessing - could be anything from an 1,800 - 2,500 stall? How do I confirm it is indeed to suit Trimatic, and not TH350/TH400?
New owner went on to purchase a manual box, so this became redundant.
Any help appreciated.
Attached File  TC01.jpg   133.1K   3 downloads
Attached File  TC02.jpg   139.4K   3 downloads
Attached File  TC03.jpg   122.42K   1 downloads
Attached File  TC04.jpg   131.16K   1 downloads
Attached File  TC05.jpg   154.79K   1 downloads
Attached File  TC06.jpg   121.96K   1 downloads
Attached File  TC07.jpg   108.83K   1 downloads
Cheers,
Brett.
#2 LXCHEV
LXCHEV
  • 3,637 posts
Posted 17 May 2025 - 09:55 PM
And how do I check to ensure this is definitely Holden V8 fitment?
#3 UCSLE
UCSLE
  • 715 posts
  • Name:troy
  • Car:Goggomobil
Posted 19 May 2025 - 01:58 PM
Dont know the difference between trimatic and th350
powerglide and trimatic are the same
Have a stock 308 trimatic converter here i can measure if you want ?
Edited by UCSLE, 19 May 2025 - 01:58 PM.
#4 yel327
  • 13,717 posts
Posted 19 May 2025 - 05:13 PM
From memory TH350 and TH400 are the same. I just measured the original GMH one out of my HJ Premier and the pump spigot is 47.6mm OD. The dick on the engine side is longer though. Hope that helps!
#5 yel327
  • 13,717 posts
Posted 19 May 2025 - 05:31 PM
I can't find Trimatic dimensions but here are the common GM dimensions, might rule some of them out:
https://non-stoptran...-converters.php
#6 rexy
rexy
  • 3,761 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 20 May 2025 - 12:00 PM
Could always drop by Andrew at AW Automatics or TCT in clayton Sth/springvale if you are out and about.
#7 greenhj
greenhj
  • 10 posts
  • Name:joe bloggs
  • Car:imaginary
Posted 20 May 2025 - 12:55 PM
Wont know whats been done to it without cutting it open but being a 12" core I'm guessing not much.
From memory you're out eastern suburbs way? Take it to TCE and they'll be able to tell you what fits at the very least. Cores are harder and harder to get, they might make an offer on it.
See if you can count the splines inside the drive and figure the PCD of the feet.
#8 Bruiser
Bruiser
  • 867 posts
  • Name:Bruce
Posted 20 May 2025 - 07:21 PM
I’ve got a standard trimatic one here
For a 6, though.
No idea if it’s the same as a v8 one
Can measure it if it’s any help
Edited by Bruiser, 20 May 2025 - 07:21 PM.
