Steering Rack Inner Seals?
26 replies to this topic
#1 Liam S
Liam S
  • 92 posts
  • Name:Liam Stephenson
  • Car:LX Torana
Posted 25 May 2025 - 05:31 PM
Hi all,
Where the hell do I source inner seals on the rack and pinions? This particular rack is from UC. Or are they just a common scraper seal?
Thanks,
Liam
#2 rodomo
  • 18,061 posts
Posted 26 May 2025 - 09:00 PM
Picture? I'm confused.
#3 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 27 May 2025 - 07:02 AM
As far as i can recall the only seal is on the pinion shaft and a boot seal on each end of rack.
#4 Dr Terry
Dr Terry
  • 3,341 posts
Posted 27 May 2025 - 07:19 AM
That is correct. There are no internal seals in Torana manual rack & pinion steering gears.
Dr Terry
#5 UCSLE
UCSLE
  • 723 posts
  • Name:troy
  • Car:Goggomobil
Posted 27 May 2025 - 02:18 PM
this one ? I have been looking for it too
 Attached File  seal.JPG   51.7K   6 downloads
#6 Liam S
Liam S
  • 92 posts
  • Car:LX Torana
Posted 27 May 2025 - 04:01 PM
Hi all, I genuinely thought the rack would have internal seals as it used to contain oil… no wonder they leaked .
The nolathane replacement bushes - they locate into the passenger side of rack I presume?
#7 UCSLE
UCSLE
  • 723 posts
  • Name:troy
  • Car:Goggomobil
Posted 27 May 2025 - 08:14 PM
yep passenger side
I am rebuilding two UC steering racks now so will post up pics when finished
The bush should come with instructions like this
Attached File  instructions1.jpg   220.91K   8 downloads
#8 Dr Terry
Dr Terry
  • 3,341 posts
Posted 28 May 2025 - 09:46 AM
We rebuilt racks for many years & we found the best lubricant to use was high temp lithium grease. If the boot was damaged, any thin oil would quickly drain out & the rack would run dry & wear the gear teeth. Grease lasted for years.
Dr Terry
#9 Liam S
Liam S
  • 92 posts
  • Car:LX Torana
Posted 07 June 2025 - 07:45 AM
Last question on the drivers side is there a bush to locate the rack? Theres a bush on the passenger side but nothing on the drivers side? Is it legitimately just the nylon tensioner pushing the rack into the pinion that keeps it located?
#10 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 07 June 2025 - 08:18 AM
Yep , it is the nylon bit that keeps it all together on drivers side , i think there is a small spring on top of the nylon guide , from memory you need to set up the retaining plate and shims for around 2 thou clearance between the top of the nylon guide and retaining plate .
#11 Liam S
Liam S
  • 92 posts
  • Car:LX Torana
Posted 07 June 2025 - 10:37 AM
Thanks mate, much appreciated.
#12 matty
matty
  • 45 posts
  • Car:1976 LX Hatch
Posted 07 June 2025 - 07:38 PM
Hey guys great info here, I have seen the two bearings and the shaft guide bush for sale but does anyone know if there is a full rebuild kit for an LX. including the shims, gaskets and rubber seal as per UCSLE Troys photo above.
Any recommendations on suppliers in WA south west.
Cheers all
Stolts
#13 Liam S
Liam S
  • 92 posts
  • Car:LX Torana
Posted 07 June 2025 - 09:46 PM
Cheers all
Stolts
I haven’t been able to find anything specifically. Shims and Gaskets look to be DIY from parent sheets. The Oil seal is the only thing that is unknown.
#14 matty
matty
  • 45 posts
  • Car:1976 LX Hatch
Posted 08 June 2025 - 08:00 AM
Seems to be the only Option Liam. I am going to have a chat with the Team at Bursons next week, If I find anything useful out, ill pop it here.
#15 Liam S
Liam S
  • 92 posts
  • Car:LX Torana
Posted 08 June 2025 - 08:37 AM
Next unusual question, my rack looks like it is bent? Deflects about 5-8mm at the geared end. Surely that isnt normal?
#16 matty
matty
  • 45 posts
  • Car:1976 LX Hatch
Posted 08 June 2025 - 01:17 PM
Could it be a worn Guide bush allowing the shaft to drift to one side. Craig from Rusty Muscle Car Garage does a great You tube Vid on rebuilding an early commodore Rack that's pretty close to a Torry rack
Edited by matty, 08 June 2025 - 01:18 PM.
#17 UCSLE
UCSLE
  • 723 posts
  • Name:troy
  • Car:Goggomobil
Posted 08 June 2025 - 04:35 PM
the early commodore rack is closer to the UC rack compared to the LX
there is only 1 gasket , i just made it from 0.15 gasket paper
no Gasket on the yoke plate
Shims are same on the pinion and yoke on the LX But the UC has round shims on the yoke side . should be easy to make
#18 matty
matty
  • 45 posts
  • Car:1976 LX Hatch
Posted 08 June 2025 - 05:58 PM
Great info, thanks Troy. So realistically all I should need to rebuild is the 2 bearings , the yoke and the Resto Country Rod end and boot kit.
Stolts
#19 Liam S
Liam S
  • 92 posts
  • Car:LX Torana
Posted 08 June 2025 - 06:34 PM
Hey mate, No its genuinely bent. From half way along the gear set, no idea how such a heavy duty rod has deflection like this. No idea how I would go about straightening this and heat treating again.
#20 S pack
  • 15,753 posts
Posted 08 June 2025 - 09:00 PM
Contact BHSS - TBS at Capalaba in Brisbane.
They recondition steering racks.  https://bhss.com.au/engineering/
#21 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 09 June 2025 - 06:34 AM
I'd say it's been in an accident, try using a press to straighten.
#22 matty
matty
  • 45 posts
  • Car:1976 LX Hatch
Posted 05 July 2025 - 04:21 PM
Wow, I thought finding the bits would be the hard part, I had never in my wildest dreams considered how friggin difficult it would be to take out the Cotter pin on the rag joint. Holy crap, the grandies have learned some new words from Opa that best not be shared with Oma in the kitchen.
I have read some previous posts but most seemed to be successful with what I have tried so far.
I am currently using a small Pitman arm puller with a flat plate with a hole in it, lots of Wurth penetrine and some Wurth Cold spray. trying to avoid putting an oxy on it as there is a little more oil under there than I would care to admit,
Any pointers gratefully accepted.
Cheers Stolts
#23 RallyRed
  • 8,203 posts
Posted 05 July 2025 - 09:13 PM
Mate, think when I had that issue with the pin...like you I cranked up the puller, with plent of lube spray like you say. Wiat a few minutes, crank the puller up even harder, then give the pin a sharp hit with a hammer , juzt like you are taking out an old ball joint. ( all from memory).
#24 matty
matty
  • 45 posts
  • Car:1976 LX Hatch
Posted 06 July 2025 - 08:53 AM
Cheers Col, I think perseverance may be the key here, with a little bit of measured aggression ha ha.
#25 76lxhatch
  • 7,222 posts
Posted 06 July 2025 - 01:51 PM
You probably know this but the pins are tapered - they can only be removed by pressing out from the threaded end. I use a pitman arm puller and a little plate too, once you finally get it in there it usually works easily enough. Can be difficult to ensure that you're not pushing against other things
