hi, ever since i finished rebuilding my car with the rear vn disc brake setup and hz fronts, thye brakes dont work the best, as if there isnt enough pressure to the calipers, it gets a bit scary at times when it wont stop, all the calipers have been rebuilt, as has the proportioning valve, what might it be?
BRAKES NOT THE BEST
_2wild4u_
, Sep 09 2006 08:48 PM
7 replies to this topic
#1 _2wild4u_
Posted 09 September 2006 - 08:48 PM
#2 _LX8VD69_
Posted 09 September 2006 - 08:57 PM
are you running a big cam? if so you probably have very little vacum for your brakes and need a vacum reservoir
#3 _2wild4u_
Posted 09 September 2006 - 09:13 PM
yeah it does have a pretty big cam, forgot about that, thanks
#4 _Aidan_
Posted 10 September 2006 - 11:52 AM
I have the same thing happening on my car
hopper stoppers kit front (au ford twin pot caliper) and vr rear brakes.
Cam is mild, big vaccum. I've bleed the brakes twice rear and front but the pedal still feels soft and has a fair bit of travel.. but I can lock the brakes up quite easily if I put enough pressure on the pedal
Posted 10 September 2006 - 05:55 PM
Don't you have to take out that olive in the rear brake line of the m/cyl.Dattoman has mentioned it before.
#6 _MAWLER_
Posted 11 September 2006 - 02:56 PM
I'd suggest with your motor it would be a vacuum issue. Do a test on the manifold vacuum and see what figures you get. I've recently had the same problem with my car and fitted a vac tank, has fixed the problem right up.
#7 _2wild4u_
Posted 11 September 2006 - 11:49 PM
cheers everyone, have you got any pics of you vacuum resrvoir setup?
#8 _MAWLER_
Posted 12 September 2006 - 07:52 PM
Check out my thread here for all the info
Vacuum Tank Topic
Car is at the transmission place at the moment, I'll get some pics of what I ended up doing when it gets back. I ended up mounting it where the washer bottle normally sits.
Cheers,
Vacuum Tank Topic
Cheers,
