um, flooding? too much fuel pressure? WTF!
#1 _oikurtman_
Posted 19 September 2006 - 06:59 PM
Still had spark. Pulled air filter off and found the carby filling up with petrol. The jets were still dripping, and the front butterflys had a fair bit of petrol sitting on top of them.
It eventually started by holding my foot flat to the floor. I got it home but as soon as a let go of the throttle it died.
I'm almost certain its got something to do with the extra fuel in the tank, as well as a part i removed a few weeks ago. It was that UFO shaped thing just in front of the carby, running in the fuel line, and has a second little pipe sticking out of it which i think goes to return line? Wasn't sure, got told to remove it.
Any help would be great as I have to drive the bastard to work tomorrow...
#2 _LX8VD69_
Posted 19 September 2006 - 07:15 PM
#3 _oikurtman_
Posted 19 September 2006 - 07:29 PM
cheers.
#4 _LX8VD69_
Posted 19 September 2006 - 07:40 PM
Posted 19 September 2006 - 07:57 PM
#6 _oikurtman_
Posted 19 September 2006 - 09:41 PM
Might just try what LX8VD69 said... I get how to check the needle and seat (I think) but still not to sure about how to reset the float level...
Edited by oikurtman, 19 September 2006 - 09:48 PM.
Posted 20 September 2006 - 04:48 PM
Unscrew the little bung on the side of the float bowl and start the engine ( turn on the fuel pump if its electric). You should see fuel JUUUSt trickle out the hole if the level is right. If it pours out its too high, if nothing comes out its too low.
TO adjust: Use teh correct size screwdriver and spanner. Release the locking screw witht eh screwdriver.. then turn the nut to raise or lower the level as needed.. then lock the screw back down!
I dont know which way raises or lowers the level though!
Good luck!
Posted 20 September 2006 - 05:32 PM
Posted 20 September 2006 - 06:35 PM
#10 _oikurtman_
Posted 21 September 2006 - 11:27 AM
Thanks for that info tiny, will do that this arvo. Had a go at the fuel level yesterday but wasn't sure where it was supposed to be.
P.S: I put a new speedo guage in the other day as my odometer never worked. It seems that I'm getting 4kms/L or 25L/100km. Is that normal?
Posted 21 September 2006 - 02:50 PM
Defintiely something wrong in your fuel system there mate, I'd suggest paying a little bit of money and taking it to a specialist who can tune the car propperly with the carby! Otherwise its just money out the tailpipe!
Posted 21 September 2006 - 06:44 PM
your running a 600 holley on a 253 eh?P.S: I put a new speedo guage in the other day as my odometer never worked. It seems that I'm getting 4kms/L or 25L/100km. Is that normal?
#13 _oikurtman_
Posted 21 September 2006 - 07:19 PM
i just went for a run up the freeway... 100kms, used just under half a tank...
Posted 21 September 2006 - 08:00 PM
I got better economy than that when I had the 650 on mine
Posted 21 September 2006 - 08:05 PM
#16 _oikurtman_
Posted 21 September 2006 - 10:34 PM
get the mechanic to tune it?
cheers.
Posted 21 September 2006 - 10:48 PM
#18 _oikurtman_
Posted 22 September 2006 - 10:04 AM
could it be that the floats are set too high?
cheers.
Posted 22 September 2006 - 08:41 PM
Posted 22 September 2006 - 10:45 PM
#21 _oikurtman_
Posted 23 September 2006 - 08:15 PM
i reset my floats yesterday. time will tell if it made any difference
booking it in for a gas conversion within the next few weeks anyway so i only have to put up with it for while, i hope.
cheers.
#22
Posted 23 September 2006 - 08:40 PM
I was suprised at how good it was as well, as I was into it a bit on the way down and chasing Knoath through the traffic so I didnt get lost!thats amazing! i would go through at least a whole tank after 200 kms...
#23
Posted 24 September 2006 - 03:17 AM
i dont think you will get much joy.thats amazing! i would go through at least a whole tank after 200 kms...
cheers.
if its not running rich and you get that economy then the motor is sad and i think you will get no joy out of stopping more frequently for gas than you are stopping for fuel now, i know, i sold a duel fuel VC commy with blue 253 for that very reason.
