VK Black 308? Good block?
#1 _rorym_
Posted 21 September 2006 - 08:15 PM
#2 _rorym_
Posted 21 September 2006 - 08:29 PM
Posted 21 September 2006 - 08:35 PM
i think the best standard webbing and reinforcement would be the VS type.
as with any block check bore thickness and any damage from previous failers and tunnel condition (straight edge should surfice), make a good visual of all threads (sometimes overlooked till reassembly)
edit; i think all late VS - VT were roller blocks.
Edited by ALX76, 21 September 2006 - 08:46 PM.
#4 _rorym_
Posted 21 September 2006 - 08:40 PM
Posted 21 September 2006 - 08:51 PM
Also depends on what bolt pattern you want as well.
#6 _rorym_
Posted 21 September 2006 - 09:04 PM
When did 4 bolt mains come in?
Posted 21 September 2006 - 09:09 PM
also VN Grp A and VS 5.7 if you can find/afford one.
Edited by ALX76, 21 September 2006 - 09:10 PM.
#8 _82911_
Posted 21 September 2006 - 10:19 PM
all the boys are on to it.... the later the block the better they are...
One thing though... check for core shift as some 308's are bad for it...
Group A VN/VL Walky or GTS 5.7 block is the best of the factory cores. Both have raised lifter bores as well as clevo sizing on the lifters,so they run more agressive profiling on the cam timing.
The be all and end all is the PE block... How serious are you going to get with this thing? Cause if it is a strictly race thing.. and you are looking to 550HP+ then you are going to need to get the block right the first time or it is going to be expensive in the long run...
At these power levels 4 bolt mains are a must.
Just wondering how deep the bug has bitten after speed on tweed....
Off topic........
You noticed how Mr Dummet drives hey!!! Flat out or get out.... certainly leaves a lasting impression!
Cheers Greg..
#9 _rorym_
Posted 21 September 2006 - 11:13 PM
Dummet is spectacular but the fastest Touring car was a RS2000 Escort!
I want 400/450 HP..reliable...thinking VN/VS 304,VN ported heads,10:1,780 DP Holley.Harrop manifold .cam to suit..still drivable ..TREMEC, VL B/W Diff 3.45 full spool. HQ pattern brakes..15 x 8, 15 x 10 hotwires..etc etc.. That should fit the bill for a fun weekend on slicks!
I entered Noosa Historic...going to fit the 13 x 7 hotwires all polished up with black centres.
Edited by rorym, 21 September 2006 - 11:24 PM.
Posted 22 September 2006 - 01:28 PM
Perkins Engineering?
Welby
#11 _82911_
Posted 22 September 2006 - 01:37 PM
that's it..PE = Perkins Engineering= the best = I'm broke
Cheers Greg..
Posted 22 September 2006 - 03:18 PM
I'm keen on hearing more about your PE engine.
I'm building an A9X Group C replica for Targa work and am getting close to the engine stage.
What do you know about Larry's engines?
Welby.
By the way, your mailbox is full.
Welby
Posted 22 September 2006 - 03:26 PM
Although I would use the new torque-power manifold,it's sounds very promising.
#14 _rorym_
Posted 22 September 2006 - 04:29 PM
Posted 22 September 2006 - 08:12 PM
edited to add, this is makka on 253toranaSS's computer!
Edited by 253ToranaSS, 22 September 2006 - 08:13 PM.
#16 _rorym_
Posted 23 September 2006 - 10:52 AM
#17 _MRNOS_
Posted 23 September 2006 - 08:31 PM
#18 _rorym_
Posted 23 September 2006 - 08:48 PM
#19 _lurkin308_
Posted 23 September 2006 - 09:19 PM
#20 _rorym_
Posted 24 September 2006 - 02:55 PM
The VN/VT block has A9X + webbing and are super strong I am told. Probably better to start with that one from scratch. If I can find a 4 bolt mains it will be all the better.
