My undrstanding is that Lh 202's did not come with WW2 Stromberg carbys.
What i would like to know is what accelerator cable to use, that will attach to Lh pedal, go through firewall nicely and reach to the carby. Fitting to the cable to the carby should be pretty easy even if minor modifications need to be made to the cable. A custom bracket has been made that comes off the inlet manifold to support the cable.
-matt
Accelerator cable to use with WW2
_just_matt_
, Sep 22 2006 02:53 PM
3 replies to this topic
#1 _just_matt_
Posted 22 September 2006 - 02:53 PM
#2 _HB1200_
Posted 22 September 2006 - 04:25 PM
I used a V8 Torana cable with my 350 Holley, The cable connection is on the same side as the WW2 so it should work, providing your bracket is made to suit.
HB1200
HB1200
#3 _just_matt_
Posted 23 September 2006 - 06:28 PM
The v8 cable worked a charm, thanks HB
-matt
-matt
Posted 27 September 2006 - 12:42 AM
For future reference, WB V8 cable are longer if you feel the turn is too tight.
