RB30ET wiring help!!
#1 _NVMYLH_
Posted 22 September 2006 - 11:13 PM
#2 _switchedon_
Posted 23 September 2006 - 12:27 AM
Posted 23 September 2006 - 12:41 AM
Hope this helps.
Good Luck!
#4 _Keithy's_UC_
Posted 23 September 2006 - 03:40 AM
He should be able to point you in the right direction!
Keith
#5 _NVMYLH_
Posted 23 September 2006 - 07:02 PM
Posted 23 September 2006 - 07:42 PM
#7 _jap-xu1_
Posted 23 September 2006 - 08:57 PM
Posted 23 September 2006 - 11:50 PM
Good luck!
Edited by rodomo, 24 September 2006 - 12:03 AM.
#9 _devilsadvocate_
Posted 24 September 2006 - 01:57 AM
My interpretation of the diagram says that whatever wire you have going to the +ve of the coil(from your ignition switch)should also go to terminal 34(it is a 12v input terminal, not an output for 12V) of the ECU and that the relay for the fuel pump gets its 12v trigger from this wire(direct from the +ve coil wire) , and that the fuel pump relay trigger circuit(solenoid) is activated by being earthed at terminal 16.
To test if the ecu is working properly in this regard, terminal 16 should provide a connection to earth for 2-3 secs when the ign is first turned to on.......terminal 34 is going to be live when ever the ignition is switched on......because thats what it is connected to. Terminal 16 should also provide a connection to earth when the motor is cranked or when it is running, but this depends on whether ecu terminal 3 is getting a signal from the tach indicating the motor is actually turning over. (the ecu having its own form of a tachiometric relay) Im not sure(looking at the diag) what sort of signal from the tach we are looking for(perhaps just the connection to the -ve of the coil or whether there is something different from a nissan tach), the tach wire actually joining the ign wire doesnt make sense on the diagram....to me anyway
Edited by devilsadvocate, 24 September 2006 - 02:11 AM.
Posted 24 September 2006 - 07:22 AM
#11 _NVMYLH_
Posted 25 September 2006 - 11:07 AM
PS- i put a similar thread on calaisturbo.com aswell, heres their info.
http://www.calaistur...ead.php?t=88242
#12 _NVMYLH_
Posted 25 September 2006 - 01:40 PM
Posted 25 September 2006 - 01:59 PM
sounds great
