GAS RESEARCH
#1 _JNR_ATE_
Posted 23 September 2006 - 04:41 PM
He told me some guys are even goin to the wreckers and getting old tanks, re- cirtifying them and fitting em again to keep up with demand.
Anyway, cant wait to see how it goes.
JNR_ATE
#2 _MediuM16A2_
Posted 23 September 2006 - 09:53 PM
what kinda of engine you running? and what GR setup did you choose?
i thinkn about converting one day.
#3 _73LJWhiteSL_
Posted 24 September 2006 - 01:16 PM
GRA gear is worth the wait mate. It is good as
Steve
Posted 24 September 2006 - 05:16 PM
#5 _JNR_ATE_
Posted 25 September 2006 - 09:24 AM
Its definately worth the wait, not having another car is the hard part.
It should be ready today, but i cant pick it up till tomorrow now.
JNR_ATE
#6 _Aidan_
Posted 25 September 2006 - 11:29 AM
#7 _dolphinex_
Posted 26 September 2006 - 12:19 AM
GRA Setup
I had 587 at the wheels with the unleaded, put the GRA on, lost 118, after fine tuning (it was 146 less at first). My car only weighed 986 kilo, (fibreglass, i love it!!!) so i was fine with the loss, as power to weight really made it not THAT much different.
If you have aspirations of a top mounted blower with gas, forget it, cost me about a grand & 3 weeks of mucking around to find out it wont work, unless you dont want to see the road in front of you...
Blower attempt...
anyway, if its just for cruising, id recommend it, you will just need to deal with heat issues if you intend to race it.
the environmentally friendly azz kicker...
GL with it,
Pete
Edited by dolphinex, 26 September 2006 - 12:22 AM.
#8 _JNR_ATE_
Posted 26 September 2006 - 10:05 AM
JNR_ATE
#9 _73LJWhiteSL_
Posted 26 September 2006 - 02:40 PM
I gained a fair bit from going from PULP - straight gas, however mine is just a stocker 173, and i did go from having a single barrel stromberg, to a 350CFM GRA carb. I have timeslips to show nearly 0.5 second gain on the quater through. It seems strange you have lost so much. What carbs were you running before the GRA stuff?
Steve
#10 _CHOPPER_
Posted 26 September 2006 - 04:33 PM
#11 _devilsadvocate_
Posted 26 September 2006 - 04:43 PM
Guys, you need to put this in perspective, this is a serious horsepower motor designed for petrol, the "things" that get the extra power obviously have some differences in a lpg applicationI had 587 at the wheels with the unleaded, put the GRA on, lost 118, after fine tuning (it was 146 less at first).
Basically any decent lpg system should work better than a basic stromberg and show at least equal power, but if you are converting a new car on fuel injection to lpg expect a slight decrease in performance.
#12 _Red Dragon_
Posted 26 September 2006 - 06:23 PM
Edited by Red Dragon, 26 September 2006 - 06:25 PM.
Posted 26 September 2006 - 06:36 PM
Devils and Dragon are both right here. That was a performance V8 built for petrol; it won't magically run as efficiently on gas. Although I am kinda surprised you didn't get a bit more power back from the professional tune.
#14 _73LJWhiteSL_
Posted 26 September 2006 - 07:46 PM
Chopper I am not tuning expert, but i pretty sure I had the car carby tuned up pretty good. I would expect part of the performance gain come from the larger throat barrel of the GRA compared to the single barrel stromberg. The carb was also rebuild (rekitted and tuned) properly when i had the car converted to manual, and i am pretty sure it has been to the carby shop since.Steve, maybe your Stromberg wasn't tuned properly before hand, which could explain the HP increase when it went to straight gas.
Just for a comparison the car was still 0.2 faster down the quater with the old stockies on it on LPG than it was with Sprintmasters and good rubber on PULP.
Steve
#15 _Aidan_
Posted 26 September 2006 - 07:58 PM
#16 _Red Dragon_
Posted 26 September 2006 - 09:10 PM
#17 _devilsadvocate_
Posted 26 September 2006 - 09:49 PM
You mean the motor octane number MON is 90.5? How does this equate to 102RON? where did you get this from, the ausfuel standard:http://www.scaleplus.law.gov.au/html/instruments/0/33/0/2003122301.htm lists only the MON number.Well since LPG has a high octane rating of 90.5 (approx 102 RON). The minimum motor octane number set for LPG in Australia. .
The RON has to be measured, not inferred from the differences commonly seen with petrol MON and RON numbers.
Anyway, glad to see there is now a standard, my motor was rebuilt for gas ~12 years ago, however, I was talked out of going further than 10.5:1 as there was no standard on the rating of the fuel.
#18 _dolphinex_
Posted 27 September 2006 - 12:02 AM
pump gas is never gauranteed for quality, if you intend racing it, id recommend getting some bottles of lpg, (BBQ style) & using that. Much better quality.
the RON of optimax would equate to a similar output of octane, compared to lpg, i would guess.
tc
peter
Posted 27 September 2006 - 12:08 AM
would not leaning out the mix reduce power?I should add you can also lean out the mixture too! (for more power of course).
#20 _CHOPPER_
Posted 27 September 2006 - 12:11 AM
#21 _Red Dragon_
Posted 27 September 2006 - 06:18 AM
#22 _devilsadvocate_
Posted 27 September 2006 - 07:32 AM
Accurate info on this is thin on the ground, I did find this site:
http://www.arb.ca.go...ge/rptjun98.htm
which lists the respective mon and ron values of different blends of lpg.
Possibly it can be inferred from this data that the ron will be at least 12 points larger than the mon. Interestingly all the blends have a larger mon than the current aus standard of 90.5.
Based on that it would be safe to design a motor based on a minimum 102-3RON
#23 _Red Dragon_
Posted 27 September 2006 - 06:31 PM
For motormouth I hope they are right for my sake as I have also been considering the option to switch.
This is for dolphinex.
Is LPG Autogas different to LPG used in a BBQ?
YES. There are two different grades or blends of LPG and they are not interchangeable. LPG Autogas is for automotive use only and will be a mixture of propane and butane. The other blend is propane, which can only be used for decanting into cylinders for barbecues, camping, caravanning and household use.
Edited by Red Dragon, 27 September 2006 - 06:44 PM.
#24 _Red Dragon_
Posted 27 September 2006 - 07:21 PM
Motor octane number 92 min; Research octane number 100 typical.
Shell is the same.
#25 _devilsadvocate_
Posted 27 September 2006 - 08:04 PM
