i have my own business making turbo manifolds,i will give you a few tips here.
if you use stainless its gotta be 321 grade.
you also have to be a very skilled welder and have a lot of experience purge welding stainless with tig or your manifold will fail.
its going to be a very expensive experiment and if your not 100% confident you can pull it off,dont even try.
if you use mild steel steam pipe bends your chances of building a good manifold that will last are greatly improved.
mild steel does not need to be purge welded,is much cheaper and does the job just about as good as stainless,especially when heatproof coated.
you can also use mig or tig to produce a decent job.
if you need any more help let me know as i do these things everyday.
here is some snaps of my recent jobs
Edited by jap-xu1, 04 October 2006 - 10:54 PM.
