Big wheels
52 replies to this topic
#1 _lxhatch_jim_
_lxhatch_jim_
Posted 28 September 2006 - 08:19 PM
Lads. I just bolted on my new 18" wheels. I'm very happy with the results
Jim
#2 _MRNOS_
_MRNOS_
Posted 28 September 2006 - 08:30 PM
Very nice...and here's what they look like in 19's
#3 knoath
knoath
    far.... FAR
  • 2,036 posts
Posted 28 September 2006 - 09:14 PM
Sorry guys.... :huh: a bit ricey for my liking. :blink:
19 inch chrome?..... :rolleyes: ... on a Torana?...I just don't get it.
Still, each to their own....I must be ageing faster than I feel I am....
#4 _LHoon_
_LHoon_
Posted 28 September 2006 - 09:18 PM
I don't quite get it either.
I figure, if you're happy to fork out big dollars for 19 inch rims and tyres, then you probably shouldn't be driving a oldschool Torana.
#5 _torona kid_
_torona kid_
Posted 28 September 2006 - 09:20 PM
wat size tyres r u running?
#6 _bodallafella_
_bodallafella_
Posted 28 September 2006 - 10:10 PM
Those little Torana brakes look extra puny behind tall wheels.
#7 dattoman
  • 16,488 posts
Posted 29 September 2006 - 12:12 AM
They need these to go with those
$3500 will do the fronts
#8 _Keithy's_UC_
_Keithy's_UC_
Posted 29 September 2006 - 01:56 AM
I wont give my opinion on the wheels til i've seen a distant daylight shot!! I've got a mate up in Townsville who's just put 19" wheels on his torry too... It depends on the daylight distant photo before you judge them...
I'll take one set of those brakes for my UC, and one set for my LX... Do they come with JAW DROP CONTROL?? What size in mm are those brake rotors??
Keith
Edited by Keithy's_UC, 29 September 2006 - 01:59 AM.
#9 _CHOPPER_
_CHOPPER_
Posted 29 September 2006 - 01:59 AM
No, but they do come with a racing harness to prevent you from putting your head through the windscreen.
#10 _lxhatch_jim_
_lxhatch_jim_
Posted 29 September 2006 - 07:48 AM
Why is that?
torona kid : tyres are 235/40 series. I'm quite confident that 245-255 would fit without rubbing on the rear but then you wouldn't be able to rotate tyres.
dattoman: tell us more about this set up.
#11 gtrboyy
gtrboyy
  • 3,235 posts
Posted 29 September 2006 - 11:12 AM
You will want bigger brakes for sure,I fitted 18in grange wheels on my lc,then put on 330mm brakes & they still look too small but I'm very happy with the way they perform.
Although I'd love a bigger set of brakes,front & back.
#12 _LX406_
_LX406_
Posted 29 September 2006 - 01:50 PM
Nup.....not my cup of tea! You cant go past the 15" racing wheel for a torana like a weld or a convo pro etc. Bling bling wheels such as these belong on cars with not much else going for them (eg. rice) Torana's dont deserved to be riced up.
#13 kudu
kudu
  • 1,466 posts
  • Car:LH SL/R 5000
Posted 29 September 2006 - 05:33 PM
Please get rid of the above photo as its hurting my eyes!!!! :D
And crickey Datto, they would need 19's to cover those dinner plates.
There is another problem with bigs rims. I only have those 17's and I can't use my front spoiler as they catch.
#14 gtrboyy
gtrboyy
  • 3,235 posts
Posted 29 September 2006 - 06:30 PM
hoppers 330mm kit
or check out their website.
Sent you a pm.
#15 dattoman
  • 16,488 posts
Posted 29 September 2006 - 09:05 PM
That pic is of 330mm discs with AP 4 pot calipers fitted on a Torana
To stock Torana spindles too
Car is owned by a forum member here
Stops good too
#16 _rorym_
Posted 30 September 2006 - 06:00 AM
Neil we need to talk soon too about what I am putting on this MHDT L34 replica.
Rory
#17 _CHOPPER_
_CHOPPER_
Posted 30 September 2006 - 07:38 PM
Stops good too
When are these kits going into production Neil? I'm waiting to send you a cheque for the adapters.
#18 _rorym_
Posted 30 September 2006 - 07:53 PM
Now I am REALLY interested...Minimum rim diameter? 15 maybe?
#19 dattoman
  • 16,488 posts
Posted 30 September 2006 - 09:03 PM
17" minimum
I am working on an under 15" size
I'm working on it Chop....... just need to get my car back so I can start playing
#20 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 30 September 2006 - 11:21 PM
Hi lxhatch jim & MRNOS. Just curious to the offset of those rims? You couldn't be so kind as to tell me could you? :D
Dattoman. I have a set of AP calipers for the front (and CP7607 series with 315mm discs for the rear). I have CRS drop axles (drilled to mount Commodore VT calipers) with hub adapters to run Commodore 330mm disc on the front. The front brake setup is the same as Phil is running on his Torana (but I believe he is using UC offset upper control arms.).
Are the adapters you are planning to design suited for direct mount to a Torana stub axle?
Edited by antelopeslr5000, 30 September 2006 - 11:25 PM.
#21 _conceptss_
_conceptss_
Posted 01 October 2006 - 02:02 AM
I reckon some of these large diameter wheels would look alright on a torana.
http://www.newstalgi...t_vintiques.asp
#22 TerrA LX
Posted 01 October 2006 - 02:17 AM
awsome find conceptss, 15's thru to 18's sweet. :spoton:
i can see someone getting a set SS wheels from here to replace a set GTS wheels.
#23 dattoman
  • 16,488 posts
Posted 01 October 2006 - 08:49 PM
Ok..... my brain is in better condition today
Phils car used CRS dropped spindles setup for Commodore brakes
So the brackets I originally supplied didn't fit. He had to make his own and move the caliper around the disc slightly
Mine will run on original Torana stubs ......... when I get around to it
Antelope........ the rear setup sounds familiar ....... what part # are the front calipers ?
#24 _CHOPPER_
_CHOPPER_
Posted 01 October 2006 - 10:26 PM
That place is in the States. There is a place locally who makes a copy of the HQ GTS rim in 17" and 18" up to 11" wide.
#25 antelopeslr5000
antelopeslr5000
  • 1,022 posts
Posted 02 October 2006 - 02:31 AM
The front calipers are CP5570's.
Edited by antelopeslr5000, 02 October 2006 - 02:37 AM.
