xu1 headers
#1 _fat tony_
Posted 29 September 2006 - 05:08 PM
Posted 29 September 2006 - 06:02 PM
If you want horsepower then bomb the eye balls out of a std 2 door not an XU1 !
My opinion anyway !!
Posted 30 September 2006 - 12:16 AM
I am interested to learn more too. I have seen and read things about wrapping up extractors to retain heat but am not sure of the reason. I fathom from that that headers would probably do that automatically? Also with the length and size of the engine pipes from the headers to the "Y" piece looks to me to be a gain. The blue/black motor exhaust manifold is effectively headers joined with a couple of extras added for inlet manifold heating. They have better flow characteristics than the old headers as they have less tight corners, but again have big engine pipes to the "Y" section. Having said all that, the EFI black motor had extractors from the factory. Is it cheaper to cast headers than it is to fabricate extractors?
Posted 30 September 2006 - 12:28 AM
Posted 30 September 2006 - 03:57 AM
Also you could get the pipes made up to look factory but with slighty larger pipe and mendrel bends to get a bit of better flow
Plus you may not be able to get historic rego with extractors (ive already asked this question before)
Loui
#6 _fat tony_
Posted 30 September 2006 - 10:51 AM
Has anyone else got an opinion on what makes more power between headers and extractors ?
If I do put extractors on has anyone been able to get the factory heat sheild back on with the extractors ? ( my heat sheild is pretty bent up so I don't mind bending it some more ).
Thanks for everyone suggestions - Fat Tony.
Posted 30 September 2006 - 11:36 AM
i use rodomo's question here as it has the essence of my answer here.Good topic!
i have never and probably never will own a hot 6 but speaking theoretically it will apply to any motor.
heat retension aids in the speed of the exhaust, the quicker it cools the slower it goes and yes cast iron retains heat better than 1mm steel.
length (tuned) in Y piece will aid in mid range torque.
tight even radius corners are better than long sweeping curves as they interupt flow more.
casting is cheeper because there is less chance of human error in mass production.
i would ask the builder for some proven gains and if you need that extra (claimed) horsepower then go headers.
or untill you get some hard facts run the casties.
there should be no need to die grind anything bar rough edges etc
ive seen a rail with hot 6 go back to the cast headers for an improvenent.
Edited by ALX76, 30 September 2006 - 11:39 AM.
#8 _LoneOranger_
Posted 30 September 2006 - 06:08 PM
I have just changed to a 3.3 Commodore engine and am a little disapointed that the headers don't fit. I will be fitting extractors only because I have to.
John.
Posted 30 September 2006 - 08:26 PM
The cast blue/black exhaust manifolds are headers. They are just joined together.I have just changed to a 3.3 Commodore engine and am a little disapointed that the headers don't fit.
#10 _Scotty_
Posted 01 October 2006 - 12:08 AM
other than that, grab a set and a set of well known brand sof extractors and get them tested for flow?
#11 _Tangey_
Posted 01 October 2006 - 12:45 AM
the XU1 headers are a really good mass produced item.
Correct length extractors will do just that, they will literally suck the exhaust
down the pipe.
Extractors cost more to manufacture so are not usually factory fitted.
Look at RT Charger, 73 Bathurst XU1, XY HO etc. all have factory fitted
extractors. Small production numbers, but homologation race cars.
The headers work fine but the extractors will work better.
Remember though it all depends on the engine you have.
The higher the specs. of the engine the greater the need to
get it in & get it out.(broadly speaking)
Heat wrapping does improve performance & heat dissipation but it alters
the steal structure, raises the carbon level making them brittle.
They just won't last as long thats all.
If it is a genuine XU1 stay with headers, if not get a GOOD set of extractos.
Something to think about.
#12 _gtr161s_
Posted 01 October 2006 - 02:28 PM
Attached is a pic of the old resonator off my lc gtr, notice how its basically straight through with a perforated pipe.
With the aftermarket resonators(hotdogs) they catch the exhaust and more than likely change its sound.
https://cache.gmh-to...trresonator.jpg
#13 _JBird_
Posted 01 October 2006 - 05:33 PM
Posted 01 October 2006 - 08:58 PM
This is true, the engine spent quite a bit of time on the dyno at Brads Speed Shop years ago. They tried heaps of different extractors and the 2 pce X2 style factory manifolds made the most torque and power. This was covered in Street Machine Magazine years ago, but still applies today.ive seen a rail with hot 6 go back to the cast headers for an improvement.
#15 _gtr-xu1_
Posted 01 October 2006 - 09:52 PM
if manifolds make more power they would of used them on 73 bath cars.
put a set of 73 bathurst spec extractors on it (i was told Reg at Australian muscle car trimming) has them
as for not getting club or historic reg with non standard exhaust (what a croc of shi%)
my cars on club reg and has extractors
yes wrong length and diameter pipe work will make power suffer but correct pipework and cam and head combination will make the best power
GTR-XU1
Edited by gtr-xu1, 01 October 2006 - 09:54 PM.
#16 _smiley_
Posted 04 October 2006 - 09:57 AM
At the A"ll Holden Day" at Carina if you had extractors and the car wasn`t a 73 Bathurst you were placed in modified.With the S.I.V rego if your cars complies with a safety certificate then it is able to be S.I.V registered..
