Has anyone ever used these? Apparently you can lower your car cheaply with this item by clamping the coils and pulling them closer together, thus avoiding cutting springs.
Any side affects? do they work?
spring locks...lowering your car
_chilzzi_
, Oct 01 2006 11:38 PM
6 replies to this topic
#1 _chilzzi_
Posted 01 October 2006 - 11:38 PM
Posted 02 October 2006 - 01:51 AM
forget that, grab an oxy, or better still but new springs to suite your car.
#3 _RpM_
Posted 02 October 2006 - 01:46 PM
Dont clamp your springs to lower your car - that only causes damage.
Buy new, or reset your old ones + shortened shocks if you want to lower it. Doing it the dodgy way may be cheap and effective now, but down the line, you're going to regret it when you need major repairs done to the car.
Plus - they are illegal, so if your car went over the pits - you be bgucked
#4 _chilzzi_
Posted 02 October 2006 - 05:54 PM
good to know
Thanks all!!
Thanks all!!
Posted 16 October 2006 - 04:41 PM
my brother had a set of these in his commo for a while, they kept popping off, im with the oxy idea, grind off a loop or two, the use an oxy to heat and bend the top rung back to the way it was and your'e done.
Posted 16 October 2006 - 05:54 PM
they are really only designed for car shows and displays ... not for driving on
Posted 17 October 2006 - 03:33 PM
pity they dont inform you of that fact when you purchase the items isnt it. they are meant to be lift kits for 4wds aswell. i would hate to try em out off the beaten track.
