tight romac harmonic ballencer
#1 _bronjak_
Posted 02 October 2006 - 06:47 PM
#2 _LHoon_
Posted 02 October 2006 - 06:51 PM
Posted 02 October 2006 - 07:12 PM
#4 _bronjak_
Posted 02 October 2006 - 10:07 PM
Posted 02 October 2006 - 10:14 PM
Posted 03 October 2006 - 01:08 PM
#7 _LHoon_
Posted 03 October 2006 - 03:58 PM
2. Tap it on a little bit with a rubber mallet, or something soft so as not to damage the balancer.
3. Buy another bolt that is longer (1/2 inch or so) than the crank bolt so that you can pull the balancer on the rest of the way.
4. Once the balancer is on most of the way, discard the longer bolt and use the proper crank bolt.
Job's done.
#8 _bronjak_
Posted 04 October 2006 - 12:19 AM
Posted 04 October 2006 - 12:39 AM
Might be enough to get it over the key and pull it the rest of the way with the bolt.
My 2c worth.
#10 _SSHatch_
Posted 04 October 2006 - 09:05 PM
It should locate correctly and you should not be able to spin it on the crank at all.its pretty tight i was worried cause if it didnt line up properly there wouldnt be much play to turn it im just curious if romacs were tighter than origional ones cheers
Kinda defeats the purpose if it can slip and turn.
Posted 05 October 2006 - 02:26 PM
I think he mean't that if he didnt have the key & keyway lined up properly he might need to turn the pulley and line them up.It should locate correctly and you should not be able to spin it on the crank at all.its pretty tight i was worried cause if it didnt line up properly there wouldnt be much play to turn it im just curious if romacs were tighter than origional ones cheers
#12 _bronjak_
Posted 05 October 2006 - 07:31 PM
Posted 05 October 2006 - 08:07 PM
no, they dontthats wat i meant i wouldnt be able to line it up if it was outa line with the key just wondering if the cranks vary with 308s as in differnt sizes where the ballencer goes on
#14 _bronjak_
Posted 07 October 2006 - 02:06 AM
Posted 08 October 2006 - 08:50 PM
