Front Springs
Posted 04 October 2006 - 07:28 PM
I am changing my LX from a 6 to an 8 as well I am putting on HQ stubs and brakes.Just wondering if anyone can recommend some springs for the front.
I priced pedders and they want $82 a spring or $164 for the front set of standard LX V8 springs (supply only).
Has anyone got recommendations on what to use ???
Either standard height or lowered and what brand.
Planning on running 205/65/14 on 14x6 wheels.
I am in the Sydney area
Obey 1
#2 _Chamois hatch_
Posted 05 October 2006 - 12:46 AM
where in sydney are you? i can recommend a place that'll help you with all your suspension worries + they know toranas well.
Posted 05 October 2006 - 12:58 AM
request this measurement when enquiring and you be satiosfied with the result.
FYI; ordering standard H/D springs will actually make the car sit higher than standard because they carry a heigher load.
Edited by ALX76, 05 October 2006 - 12:59 AM.
Posted 05 October 2006 - 07:30 AM
Chamois Hatch ..I work out of Zetland and I am mobile so I can probably get around , if you could give me your suspension contact, that would be much apprciated, and yeah I thought $164 for the pair was a bit pricey??
ALX76 ...
I have the front end in pieces at the moment ,so it will be a bit hard to measure ,but if I was to put it back together(mock up) what positon should the arms be in to get the correct reading for the axle Height ??
Thanks Again
Obey 1
Posted 05 October 2006 - 11:55 AM
I think my front springs are lowered pedders and with the HQ stubs the front is verrrry low
Posted 05 October 2006 - 06:10 PM
you should have the bottom arm sitting level at normal ride position for the best handeling.Thanks for the Help..
ALX76 ...
Thanks Again
Obey 1
as for looks well the lower is the better eh?
#7 _CHOPPER_
Posted 05 October 2006 - 07:12 PM
#8 _jimjet61_
Posted 05 October 2006 - 07:43 PM
Posted 07 October 2006 - 06:42 AM
Thanks for both your replies.
Hopefully I can find a place in sydney that does good springs for the right price ,as I think the time I get them shipped interstate , it would probably cost me more!!
I could be wrong though.
Chopper..I understand your a bit of a suspension Guru..would you go for standard height or lowered springs??
I am just after something that will handle nicely.
Thanks again...
Obey 1
#10 _CHOPPER_
Posted 07 October 2006 - 11:05 AM
#11 _Chamois hatch_
Posted 07 October 2006 - 01:23 PM
Posted 07 October 2006 - 07:19 PM
Chamois Hatch..thanks for the Lead ,I have looked him up in the Phone book and I will contact him next week.
Cheers guys
Obey 1
#13 _CHOPPER_
Posted 07 October 2006 - 07:39 PM
Going by what you posted, I would be aiming for:
Castor: +0.5
Camber: -1.25 +/- 0.25*
Toe in: 2.5 MM
If you have the same thickness washers in all four positions, try ( 2 ) 1/8" shims in both front bolts and ( 3 ) 1/8" shims in both rear bolts. That should be a reasonable initial setup until it gets aligned properly.
* As you will be running HQ stubs, you may run out of adjustment trying to reach that camber figure.
Posted 11 October 2006 - 08:17 PM
Sorry I havent got back to you for a while, been busy !!
I rang Jim Hunter and he quoted me $125 for front HD standard height Springs.
A fair bit cheaper !!
And Chopper I had a look at the washers the front ones are Approx 9.5mm(11/32") and the back ones appear to be 13mm(1/2") that was the best I could read with a steel ruler, so I am guessing the shim setup will be a bit different to what you 1st quoted ??
If you get a chance please let me know what shims for initial setup.
Oh and yeah the steering arms are heat treated.
Thanks Heaps Guys..
Obey 1
Posted 11 October 2006 - 10:15 PM
I just had a look at the steering arms I have and you would not be able to bend LX ones to the same as A9X as they are physically too short. UC ones you would probably be able to but I just buy the Harrop ones when I need them.
M@
#16 _Chamois hatch_
Posted 11 October 2006 - 11:58 PM
#17 _jklumpp_
Posted 12 October 2006 - 01:26 PM
#18 _82911_
Posted 12 October 2006 - 03:10 PM
was pitted next to Jim at the muscle car masters.. till he popped his head gasket and went home...
VERY KNOWLEDGABLE and personable bloke....
I don't think you could go too far wrong if you take his advise..
HE HAS BEEN THERE AND DONE THAT.. UNLIKE A LOT WHO SUGGEST THINGS ON THIS FORUM....
Cheers Greg..
Posted 12 October 2006 - 04:34 PM
Is that correct ,so now the Top control arm bolts hard up to the Cross member (give or take the correct shims for initial setup).
Is that right ??
As far as the steering arms..I am relying on a mates correct info..
He tells me the guy doing it use to set up cars for Bathurst with this technique??
Fingers crossed!!!
and I am hoping to visit Jim hunters suspension over the weekend , I might put to him what I am planning and Hopefully he can point me in the right direction.
Obey 1
#20 _82911_
Posted 12 October 2006 - 05:25 PM
Good idea.. do that.
He used to race an L34 for the HDT as well you know and was widely regarded as an "Amaroo expert"
Cheers Greg..
#21 _CHOPPER_
Posted 12 October 2006 - 07:53 PM
Ideally, yes. If "close enough" is good enough for your alignment settings, or you can't be bothered removing the spacers, leave them in. Please note that if you were using standard Torana stub axles, they could be left in place without too many dramas.Thanks Toranamat69 .. But .Now I am confused a bit... So the large steel washer or spacer tubes are suppose to be removed??
Is that right ??
#22
Posted 14 October 2006 - 09:26 AM
Hoping to get there shortly..oh and they are only $125 for the set, which is a bit of a cash saving as well.
Thanks for all the Help Everyone !!
Obey 1
#23 _CHOPPER_
Posted 14 October 2006 - 12:45 PM
#24
Posted 21 October 2006 - 09:35 AM
$125 Standard height HD.
Thanks again to those who gave me input.
Tick off item 55 off 1000's of the To Do list.
Obey 1
