350 Chev in LH..Box?
7 replies to this topic
#1 _rorym_
Posted 05 October 2006 - 05:46 PM
What are the opinions of a g/box behind a 350 Chev in an LH? Bearing in mind I dont want to pay $3000 ... Muncie M22? Tremec TKO? Ford?
Let the discussion begin.
#2 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 05 October 2006 - 08:16 PM
T10?
#3 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 05 October 2006 - 08:34 PM
Rory, bang for your buck, with reliability in mind, can't go past the old Ford Toploader. People say they don't like to shift very much, but I never had any drama's with mine shifting up to 6500rpm. They are pretty strong, easy to come by, and won't break the bank.
Tremec's are awesome, but you wont see much change out of 5 or 6 grand by the time you get it in there. $3000 will see you a toploader with plenty of change, or if your lucky maybe even a super T-10. Super T-10's are known for their great reliability and smooth shifting at almost any rpm.
Dave
#4 Racehatch
Racehatch
  • 1,027 posts
Posted 05 October 2006 - 09:14 PM
I agree with 355LX
I'm running a toploader in mine, there are a few mods you can do to help with the shifting, and running the right oil makes a big difference... I use a good quality 80W140 (sounds heavy I know, but in a high temp race situation its the go).
This is a good website for more info:
toploader website
cheers,
Sam
Edited by 350LH, 05 October 2006 - 09:17 PM.
#5 _MRNOS_
_MRNOS_
Posted 05 October 2006 - 09:18 PM
What shifter do you guys run?
#6 Racehatch
Racehatch
  • 1,027 posts
Posted 05 October 2006 - 09:23 PM
I'm running a hurst indy, one of the things that really helped was changing the standard hurst shifter lever for a much longer one, so you dont have to move your hand so far from the wheel, which helps when things are happening in a hurry... :)
#7 _rorym_
Posted 07 October 2006 - 05:59 PM
Its looking like thats the go for $ and reliability.
#8 LS1LX
LS1LX
  • 1,931 posts
Posted 08 October 2006 - 02:06 PM
You wont setup a Muncie, Super T10 or Tremec for under $3000, most will be more.
Cheapest option is Toploader, then Celica 5 then a T5.
We just put a Toploader behind our SBC, we already had the reco box, another $1500 for clutch, pressure plate, flywheel, speedo cable, shorten tailshaft, x member, mount and shifter. Not including labour or the cost of the trans. Bet on $3k and you'll be right.
