I have a few questions for you.
:What grade oil do you guys use in an lsd diff?
:Any Idea how much oil a 9 inch diff takes?
:how to fill it if it has no plug on the back (is this done through an axle tube?)
:Also how to check level if it has no plug on the back?
Just got a feeling the guy who built it didnt put any oil in it.
took out an axle halfway to replace the competition studs it has and didnt notice any gear oil smell.
Just want to make sure she is ok before I actually drive it.
Before anyone asks the diff bloke says he doesnt know as he was on his honeymoon when it was built and the guy that assembled it has left.So he doesnt want to guarantee it has oil as he wasnt there etc.
9 inch diff oil questions
_ChiaLX_
, Oct 08 2006 08:54 AM
6 replies to this topic
#1 _ChiaLX_
Posted 08 October 2006 - 08:54 AM
Posted 08 October 2006 - 09:52 AM
Most places dont put oil in the diff when it is built, they leave that up to you.
#3 _HB1200_
Posted 08 October 2006 - 10:15 AM
I was told by the guy who built mine to use LSX85/140 with a small bottle of friction modifier. There should be a plug on the passenger side of the diff center, from memory it is a 3/8" square drive. I'm not sure how your supposed to check the level, you may just have to meter how much you put in.
HB1200
HB1200
#4 _ChiaLX_
Posted 08 October 2006 - 10:30 AM
Tinks , My diff bloke says he normally does but it isnt standard practice and because he wasnt there he cant tell me.
hb1200: thanks I found the plug.
Still needd to find out how much it takes.
I might just call up the diff bloke during the week.
Thanks guys ang girls.
Posted 08 October 2006 - 11:39 AM
Buy yourself a "tom thumb" pump... and keep on pumping till she trickles out the filler hole.
a 9" diff is full when you pump oil into the housing and it just trickles back out the filler hole.
Just make sure that its not just hitting the side of the gear and "splashing" back out.. and make sure that there's not an air bubble sorta forcing the oil out.
You'll know when its full!
I dont know how much it would take though! from MENORY it was around 1.5-2L?? i could be way off the mark though.
Posted 08 October 2006 - 06:25 PM
I also used LSX 85/140
2.1 Lts to be exact
2.1 Lts to be exact
#7 _ChiaLX_
Posted 08 October 2006 - 07:18 PM
Thanks heaps people, all the info I needed. what a great forum we have !
Mick
Mick
