What size Stall Convertor to use????
#1 _J&S Racing_
Posted 17 October 2006 - 06:39 PM
The 286 cam starts at 2200rpm so would it be ok to say i might get away with a 2500 Stally? when i rang TCE they said i would need a 3000 or 3500 Stally, now that sounds a bit to much what do you think?
Steve
#2 _timbotorrie_
Posted 17 October 2006 - 07:32 PM
they will make one to suit YOUR car!
#3 _STEVO_
Posted 17 October 2006 - 07:38 PM
if so go 3500 dont forget they wont stall to that in normal driving
i ran a 4000 in my old como with 4.11 gears and it was a daily driver
If your worried about fuel go smaller but if thats a worry we would be driving 2lt cars
hope that helps
#4 _J&S Racing_
Posted 17 October 2006 - 07:49 PM
STEVO the car is mainly used for cruising and a bit of strip so i don't want to go to big, fuel is not the issue it's just a matter of getting the most out of the power range of the cam and not going past it before it really gets used, thanks for your input everything is taken on board.
Steve
#5 _LHoon_
Posted 17 October 2006 - 08:17 PM
I have had 2500rpm converters in the past, and you can hardly even notice that they are higher than standard. They are not much better than standard, considering that many stock converters stall speed is 2100-2200 rpm.
The only consideration really, is how much time will be spent on the freeway. If the answer to this is quite a bit, then maybe tone down the stall speed a little and settle for a bit of a compromise 2500-2800 stall. Otherwise, go for the 3000 or 3500 stall!!
#6 _MAWLER_
Posted 17 October 2006 - 08:28 PM
Peace,
#7 _[BOTTLEDUP]_
Posted 17 October 2006 - 10:07 PM
308s with 286s need more stall than the cam range states, 3500 being the ideal.
#8 _DocDamage_
Posted 17 October 2006 - 11:47 PM
Posted 18 October 2006 - 10:17 AM
In the coupe i've got a 2200Rpm domintor stall.. The cam is only a baby and is supposed to work from around 2500-6000. With the 3.2 diff ratio and 28" tall tyres i ran a 12.4 crossing the line at around 5500 Rpm.
Changing nothing else ( basically), but going up to a 3.7 diff ratio, how do you think this will affect teh stall speed?
is it likely to change the stall speed, or nothing at all ( other than the car's acceleration).
And i was advised to go a small stall because of the cruising and street driving that the car does.
If i were to go a bigger 3000-3200 stall what would the net effect be on the components? Is it true that any revs under say 3000 on the tach will allow the gearbox to slip creating bulk heat? Or have i been advised incorrectly?
Sorry for the thread steal, but i think its along the same lines and may help to further inform us all! ( especially me! LOL!)
#10 _J&S Racing_
Posted 18 October 2006 - 04:44 PM
All is welcome Tiny, it's good to have others ask different questions the more the better as it gives us more info on things we don't know.
Cheers Guy's
Steve
#11 _lurkin308_
Posted 18 October 2006 - 06:23 PM
#12 _STEVO_
Posted 18 October 2006 - 06:24 PM
which will run a quicker 60 foot and ET
Tiny thats a very good time you ran how much work have you done engine wise
Also what MPH did you cross at
Cheers Stevo
#13 _J&S Racing_
Posted 18 October 2006 - 08:24 PM
I think the machanic set my cam at 3 degrees advance. When advancing the cam what do you need to take into consideration? eg valve piston clearance and then what dizzy timming?
#14 _lurkin308_
Posted 18 October 2006 - 08:54 PM
#15 _HatchmanSS76_
Posted 20 October 2006 - 10:54 PM
As plenty of others have said, some where in the 3000 mark would be good.
I went to a 4500 in the 304 motor. Had that one purpose built for the stats on the engine, trans and diff. Was told after sending in all the info that reason it was that was due to the small cubes of the motor. Told them I was thinking of stroking the motor to 355 later. They advised me to have another one built than and around 3500-3700 would be the go to suit the bigger cubes.
#16 _V8Hatch_
Posted 22 October 2006 - 08:52 PM
Now i will have to run an oil cooler, what size will do the job? also i was thinking of plumbing the one cooler line from the auto to the bottom of the radiator then out the other end of the raditor to the new cooler then back to the auto, is this what others do and does it matter which line goes to the radiator first?
Steve
Posted 22 October 2006 - 09:33 PM
Tiny, firstly that cam is NOT small. I had a considerably smaller cam in my 350 and I used 4000rpm stall.If i may deviate the thread slightly...
Changing rear end ratio will not affect the stall speed.
I would definately recommend a 3500 odd stall for your beast, the fact that you don't drive it daily means you can get away with a larger stall. Also using numerically higher diff gears makes the higher stall more user friendly.
JMHO
Posted 23 October 2006 - 09:42 AM
Will think more about this!
Posted 23 October 2006 - 01:27 PM
http://www.accelerat...om.au/index.htm
John Mournas is the guy you should talk to.
#20 _Lostit_
Posted 23 October 2006 - 10:25 PM
#21 _V8Hatch_
Posted 24 October 2006 - 06:14 PM
#22 _timbotorrie_
Posted 31 October 2006 - 05:48 PM
Edited by timbotorrie, 31 October 2006 - 05:49 PM.
#23
Posted 01 November 2006 - 02:00 AM
#24 _V8Hatch_
Posted 01 November 2006 - 08:12 PM
#25 _STEVO_
Posted 01 November 2006 - 08:25 PM
you will have some fun,it will launch harder and sound alot tuffer
ill be running a 5500 in mine(more race but some street)
