Spacers Converting UC stud to Commo
#1 _LX_SSnatch_
Posted 05 November 2006 - 09:09 PM
Im 17, and about to purchase a set of 17' Advanti wheel for my UC Hatch and being commo stud i have to change my stud pattern. The wheel shop i was at said i can order Spacers to convert it from UC to Commo
What is ure view on this idea?
And has anybody got them on a UC or and torana that is that could tell me abit bout them?
Any info would be great
Matt
Posted 05 November 2006 - 09:15 PM
Sarsha did it. See if you can find her old thread on it..... search button is under "my assistant" on the right
I rekon modern wheels look ugly
Not to mention the extra load on the bearings from the spacers and the brakes because of the larger rolling diamter
Each to their own though
A few people selling them on ebay ....... go look
#3 _CHOPPER_
Posted 05 November 2006 - 10:03 PM
Welcome aboard and feel free to ask questions before spending money, we could save you heaps.
Posted 06 November 2006 - 10:14 AM
I haven't seen any in shops, and don't hear many people talk about them.
I know there are spacers as purely spacers to fit new wheels to old cars, but what about these PCD altering ones?
I spose CHOPPER and Dattoman are the ones to ask here... what's the legality of using these spacers?
(sorry to steal thread here, but here goes)
I'm having trouble finding any decent rims for the UC and would love some 16x7 Walky rims.....
Are these spacers legal, and will they be detrimental to my bearings to the point they'll fail? Or can I buy H/D bearings?
Posted 06 November 2006 - 10:49 AM
also i remember somebody saying once that they were able to fit like VB/C axles into there torana diff.... im really not sure how true it is, but it could be a safer option than puting these spacer things on...
#6 _Leakey_
Posted 06 November 2006 - 03:53 PM
and doing an HQ change over?
I've not heard of these spacers before?
- Leakey
Posted 06 November 2006 - 04:57 PM
http://www.dotars.go...n/vsb_ncop.aspx
It would appear that the adaptors are not legal. See page 15 of the document below.
http://www.dotars.go...ng_3Feb2006.pdf
#8 _CHOPPER_
Posted 06 November 2006 - 07:30 PM
Posted 06 November 2006 - 08:57 PM
Thanks CHOPPER.
Matty, all points taken into consideration.
Thanks.
#10 _Oldn64_
Posted 07 November 2006 - 02:50 AM
Please do not do this. HQ pattern and Commodore pattern are two very very different patterns. One being metric the other imperial. There is enough of a difference that the studs can fail and cuase untold damage to your car and others around.In terms of cost, what would the difference be in using these things
I found this out the hard way a long long time ago. This occured due to a tyre fitter telling me that they where the same. Took 18months but one wheel did fail and fall off. it also took the drivers guard off at the same time. do the change right the first time..
#11 _Leakey_
Posted 07 November 2006 - 08:48 AM
difference.
The spacer/adaptor is on Ebay for about $260 which opens up the world
or Commode rims, and I do not know how much an HQ conversion
would set me back, also opening up the world of HQ etc rims.
More a price Q.
- but thanks for letting us know that story. I am sure we've all done
something like that on the advice of an 'expert' just trying to sell
something. That's why this forum is so good. Many heads.
Cheers, Leakey
#12 _Oldn64_
Posted 07 November 2006 - 12:57 PM
Leakey,The spacer/adaptor is on Ebay for about $260 which opens up the world
The price for a HQ conversion is not that much. The fronts are easy as with the use of hq discs and calipers etc. The rears are easy too, but I am not sure of the lengths in a torana. For other vehicles (ie HK etc) a HQ axle from a 6 cylinder will fit into the original housing with just a little trimmed off the ends so they do not meet. I would expect the same would be true in the Torana if the diff length is similar. Something to find out, I suppose. So really for less than the $260 you potentially will be able to do the conversion with just going to your local self serve wreckers. Your only draw back is that the wheels are still not on the car at this stage so a wheel costing is still required.
#13 _LX_SSnatch_
Posted 07 November 2006 - 08:34 PM
#14 _Oldn64_
Posted 07 November 2006 - 08:51 PM
Just remember that the Torana stub axle is the only one with that inclination and thus a Hr, HG, or HQ stub will lay the front wheels over agressively.
#15 _CHOPPER_
Posted 07 November 2006 - 10:18 PM
#16 _Oldn64_
Posted 07 November 2006 - 11:15 PM
#17 _Keithy's_UC_
Posted 08 November 2006 - 07:18 AM
I would not use the wheel adaptors (things that change stud pattern), there is too much risk involved in the use of these. For safety reasons i wouldnt go them...
Keith
Posted 08 November 2006 - 11:23 AM
Tim, the standard LH/UC swaybar is rear mounted, a front mount might help.....That was my point, my concern was more in teh inner gaurd and fron leading edge of gaurd, but if sway bar the issue then it is a bigger problem. Wonder if a rear mounted front bar would assist or hinder this..?
#19 _CHOPPER_
Posted 08 November 2006 - 03:42 PM
Edited by CHOPPER, 08 November 2006 - 03:43 PM.
#20 _torana_
Posted 08 November 2006 - 04:04 PM
woah, be carefull there chopper.Because they are an adapter, NOT a spacer, they are legal. A spacer sits on the hub to increase the track. As these adaptrers are bolted to the hub, they are then considered part of the hub and therefore legal.
Read the rules here
http://www.rta.nsw.g.../vsi09_rev4.pdf
they state
The fitment of wheel spacers (or adaptors for dual wheel conversions) between the wheel mounting face and the road wheel is not permitted unless fitted as original equipment by the vehicle manufacturer.
If you are prepared to go to court and argue that an adaptor is not a spacer, good luck. If you do intend to run adaptors, get them approved ( if you can ) by an engineer. He may ask you to chemically bond them to your discs or drums ( not sure how / weld ? )
just my two cents worth
cheers julian
#21 _CHOPPER_
Posted 08 November 2006 - 04:13 PM
#22
Posted 08 November 2006 - 04:18 PM
Edited by FastEHHolden, 08 November 2006 - 04:19 PM.
#23 _torana_
Posted 08 November 2006 - 04:19 PM
#24
Posted 08 November 2006 - 04:21 PM
#25 _torana_
Posted 08 November 2006 - 04:25 PM
