Door belt rubber clips
Posted 29 December 2006 - 04:48 PM
Rare spares makes the rubbers but it seems that nobody makes the clips!
Is this true ???
_LXChev366_
Posted 13 January 2007 - 03:29 PM
_Toranaman24_
Posted 13 January 2007 - 03:51 PM
r u talking about the out side door belt, because 2 days ago i bought the inside and out door belts from a rubber shop for a 2 door LJ and he said that they don't make them with the clips any more, he told us we needed to glue the outside belt on. but the inside one came with clips
im sure u could find spares at ur local wreckers and attatch them some how.
hope it helps
Matt
Posted 13 January 2007 - 04:08 PM
_devilsadvocate_
Posted 13 January 2007 - 05:17 PM
If anyone wants to compile a "How to do it section on these" there will be at least one reader!
Posted 13 January 2007 - 05:20 PM
So a pic or a detailed drawing would help.
_Yella SLuR_
Posted 13 January 2007 - 06:04 PM
LH you have some advantage in that the outer connects into the chrome strip, so it can be removed from the car for fitting.
I know the door belts in the Commondore are glued in, as I've had to reglue 3 of the 4 doors so far.
One of the things I forgot to try buy at the Nats. Get that with old age.
Posted 13 January 2007 - 06:09 PM
_Yella SLuR_
Posted 13 January 2007 - 09:07 PM
If it's of any consequence and you have to resort to glue, I use Quik Grip on the Commodore, same stuff your kitchen laminate is put on with. Applies to both surfaces, let cure for 15 minutes, then push the two surfaces together.
Edited by Yella SLuR, 13 January 2007 - 09:08 PM.
Posted 13 January 2007 - 10:08 PM
Posted 13 January 2007 - 11:09 PM
_keith1962_
Posted 14 January 2007 - 09:19 PM
because they carry a lot of $h!t for our cars
cheers Keith
Posted 15 January 2007 - 06:43 PM
Do you know if they have these clips ?
_gtr-xu1_
_Yella SLuR_
Posted 26 January 2007 - 01:12 AM
Door belts are still in good condition, so would be a waste getting whole new door belts.
Edited by Yella SLuR, 26 January 2007 - 01:13 AM.
Posted 26 January 2007 - 12:44 PM
maybe i can help.. the word is "maybe"
_gtr161s_
Posted 26 January 2007 - 01:42 PM
with glue technologies going leaps and bounds im sure they would have a product to replace those clips\.
they use these types of glue to joint car panel to avoid heat etc, saves time and money for the manufacturer so it must be good
_LXChev366_
Posted 26 January 2007 - 09:10 PM
_LXChev366_
Posted 26 January 2007 - 09:19 PM
check your emails I sent you a pick..
_Yella SLuR_
Posted 26 January 2007 - 10:11 PM
#21
Posted 27 January 2007 - 08:45 AM
hopefully we can find some, i actually call them weather strips,
watch this space
Posted 30 January 2007 - 03:34 PM
something similar that will do the job just the same or better or
possibly get made if it doesnt cost an arm/leg
i probably would be looking at around 1000 clips.. we will see what this fellow says
i explained there is a rather large torana comunity needing these special clips
#23
Posted 30 January 2007 - 06:13 PM
Keep us posted!
L
#24
Posted 31 January 2007 - 11:24 AM
i will beleive it when i see it
#25
Posted 31 January 2007 - 02:40 PM
