My '76 LX Project
#101
Posted 10 April 2007 - 09:08 PM
#102 _Azza_
Posted 10 April 2007 - 10:42 PM
Keep up the good work
PS: I'm winning muhahaha
#103
Posted 10 April 2007 - 11:44 PM
yeah the one am replacing it with is slightly bent which annoyed me some what because i didnt realise this until AFTER i had cut them both out... so i have straightened it as best as i could so hopefully the panels line up when its welded in place... *fingers crossed!*
#104
Posted 22 April 2007 - 06:48 PM
heres a couple of pics:
Leigh
#105
Posted 05 May 2007 - 01:01 PM
Any help MUCH appreciated. Leigh
#106
Posted 05 May 2007 - 01:39 PM
Hows the one on the spare parts car, maybe you could swap them over
Chears Neil
#107
Posted 05 May 2007 - 01:43 PM
The beaver panel is fine i am able to swap that over from the parts car.
most of the boot section of that rust i can get from the parts car but the rear quarter section i can't as that too is rusted out on the parts car...
i guess i could cut out the rail from the parts car but will that effect the strength of it in anyway?
Leigh
#108
Posted 05 May 2007 - 03:01 PM
As you can see the lower quarter is stuffed so i cant use that part of it... what do people think? where should i go from here?
Cheers Leigh
#109
Posted 05 May 2007 - 04:43 PM
Once welded up should be just as strong as before. You might be able to patch up the rail off you donar car with some more steel and shape it with a hammer and dolly. If you get realy stuck you might have a pannel beater who might do cash jobs after work might be able to help. I feel sorry for you guys having rust, my torry seems to of escaped the dreaded tin worm.
Chears Neil
#110
Posted 05 May 2007 - 05:03 PM
your a lucky man if your car has escaped it!
Thanks Leigh
#111
Posted 05 May 2007 - 05:33 PM
I was smart enough to not cut that section of my car out (i missed it by about 50mm lol) so even if it is rusted, I don't have to worry about repairing it.
#112
Posted 05 May 2007 - 06:16 PM
Heath have you done anymore to your torrie, i havenot seen an update for awhile. I was looking on ebay and theres an old lh the same coulor as yours
Chears Neil
#113
Posted 06 May 2007 - 01:34 AM
lol! yeah i really should stop hunting for the stuff... its always FAR worse then what you first expect! things are slow though...That section of the chassis rail isn't even really structural metal... or it's not important structural metal anyway. If you get rear ended hard, it's gonna need to be replaced anyway. So it has very little purpose. Fix it so it looks good enough for you to be happy with it, welding it should make it much weaker anyway if it's done half-decently.
thanks for the replies
#114
Posted 06 May 2007 - 12:55 PM
Tim
#115
Posted 06 May 2007 - 01:21 PM
#116
Posted 06 May 2007 - 06:07 PM
^ oh sweet! good to here. yeah bodywork... i have no clue either Heath! so far i have just been making it up as i go along...
#117
Posted 06 May 2007 - 06:15 PM
next question is does anyone have a welder they want to lend me?
Leigh
#118
Posted 08 July 2007 - 11:49 AM
Anyways ill keep you posted as things start to progress!
Cheers Leigh
Edited by toryman76, 08 July 2007 - 11:50 AM.
#119
Posted 08 July 2007 - 12:12 PM
#120
Posted 08 July 2007 - 01:17 PM
btw has anyone had any experience with gasless welding of cars? only reason i ask is i got a roll of gasless wire with the welder.
#121
Posted 08 July 2007 - 08:28 PM
#122 _Azza_
Posted 08 July 2007 - 11:33 PM
Throw that shit in the bin and go buy some gas and some decent wire
Hurry up mate Ive got a bit further ahead of ya now.. Chop Chop
#123
Posted 12 July 2007 - 03:06 PM
azza i tip my hat to you if you have managed to do your welding with gasless as i found it impossible to weld thin metal from the torana!! i was just practising on a bit of scrap and i could manage a shitty tack but found it impossible to try and make a continuous weld without burning through. i had the welder set to minimum settings too....
the plan was always to go with gas wire so thats definately what i will be doing, and plus this gasless stuff is bloody messy!!!! its worse then a arc welder!!!! anyways hopefully getting some gas wire tonight 0.6mm and then try and organise gas sometime in the next week, then i should be able to do a bit better.
mind you i did do a bit of welding on some thicker material and the gasless stuff produced a beautiful weld, and i had just randomly set the settings on the machine!
anyone have any ideas on how i should go about making a trolley for the welder?
Posted 12 July 2007 - 09:42 PM
With a welder
Got a pic of the welder? That'll help for ideas for a trolley.
Tim
#125 _Azza_
Posted 13 July 2007 - 07:41 PM
